Results 1 to 19 of 19
    Nov 2007
    hi guys
    sasakyan ng wife ko biglang nag iba konsumo ng sasakyan nya at bigla humina hatak na rin
    itong linggo lang nagsimula lahat
    sunday - pa gas full tank
    Weekdays - opis bahay lang (5km total of 10km balikan)
    Tuesday - kinuha ko sa opis nila at inuwi ko sa bahay, hapon sinundo ko
    Aircon seldom use
    ngayon kalahati na ung gas nya
    Nissan Lec 1.3
    saan pde unang tignan
    Last Maintenance
    OIl change / OIL filter change - 5 months ago
    Fuel filter - cleaned up last 2 months ago
    Spark plug - 7-8 months pa lang , but nilinis kasabay ng fuel filter cleaning
    checked
    - NO dark smoke (White smoke occur only during morning after car start but nawawala din after a few minutes , malamig kasi dito sa amin
    - on idle, check oil no blow by.. pag taas ko ng dip stick may pressure pa rin
    - on idle, check spark plug.. kada angat ko tumutunog parang tik tik tapos ung color ng spark is somewhat light blue, or white
    - no oil leak
    Aug 2004
    5kms is pretty short. It'll help if you measure your consumption exactly (in kilometers per liter).
    With the 1.3 LEC, you have to clean the carburetor out every 5,000 to 10,000 kilometers to keep the fuel economy good. All it requires is a good spray of carb cleaner and choking the carb. Also check the condition of your air filter.
    Nov 2007
    before this happen
    the consumption before was
    on highway (14 to 17km/l).
    on city driving ( 10-11km/l)
    carbs cleaned i think last year, i got carb spray here
    What gasoline did you use? Maybe it was an E10 gasoline brand?
    Nov 2007
    hmm.... GOLD (caltex)
    when E10 implemented hindi na ko nagpa gas ng Silver
    and if in case nagpalagay ng Silver there will be a slight different in FC but not that too much
    May 2004
    ganun din FE ng kapatid ko... average ko 7km/l lang then 8km/l naman nung nag tagaytay kami... so sad... hehehe
    Nov 2007
    up up up ko lang
    May 2004
    Quote Originally Posted by jansky View Post
    up up up ko lang
    I think 1st sir tune up muna... palit fuel filter, air filter, oil and sparkplugs. Then palinis ng Carb using carb cleaner. pa check na rin yung breaks and wheel bearing kung need to replace na din. Camber alignment na rin po. Sama niyo na rin yung tire pressure sir.
    Most owners sometimes neglect to use there car for long driving or highway driving to let all the carbon let out on the exhaust pipe . Have you noticed that when you use your car for a long drive you feel something different on acceleration of the car it feels light compared to use it on a city driving in a 5 to 10km a day . Just my observation.
    May 2004
    Yesterday I had my Brothers FE tuned up... Looks like this time nakuha na yung tamang timing... The engine feels more responsive than before... hopefully by next full tank we can achieve better millage... Bro pa tune up mo muna mabuti and check timing...
    Nov 2007
    thanks guys
    after tune up
    smooth na ulit takbo
    last week went to tarlak and the consumption back to normal
    di ko na rin marinig ung tunog ng makina parang nakapatay makina pag tumatakbo as in silensyo cya
    Italian Tune up d best pa rin
    May 2004
    thanks guys
    after tune up
    nice... ako din umayos eh... tancha ko nasa 9 to 10 km/l Hintayin ko pa next full tank ko... hehehe
    Oct 2005
    ano ba normal consumption ng LEC mo sir jansky? na curious ako. mukang matipid ah
    Nov 2007
    Quote Originally Posted by basti08 View Post
    Sir
    on highway (14 to 17km/l). (speed 70-90 km/h)
    14 km/l (loaded)
    on city driving ( 10-11km/l) (worst 5-6 km/l)
    sabi nila matipid nga daw ung saskyan (baguio - manila one full tank may extra pa na natira )
    Oct 2005
    Huwow!!! ang tipid nga!
    thanks guys
    after tune up
    Try to check next time you will go for a long trip observed the carbon on your tail pipe if the carbon is whitish meaning to say your engine is in good condition and the fuel burn well.
    Nov 2007
    Quote Originally Posted by speed unlimited View Post
    Yes it is ...
    hi guys
    Aircon seldom use
    Nissan Lec 1.3
    Last Maintenance
    checked
    - no oil leak
    MIGHT BE SLIDING CLUTCH. Please check
    tune-up might be needed. Not just replacing the spark plugs but with valve clearance adjustments.
    you might also want to check on the exhaust pipes, baka may butas (not needed if wala namang nadagdag na ingay sa tambutso)
tumaas sa konsumo ng gas humina pa hatak
