Results 11 to 17 of 17
- 52,731
June 10th, 2017 08:44 PM #11if you will not use any gasketmaker, as what some recommend, simply wipe the mating surfaces with a cloth to remove particulate matter and excess oil, so that they are dry. you might have to use some brute force with a blunt edge, to remove solidified gums.
how much the gasket? i... don't know. haven't bought one in ages.
kung may yupi, it will have to be straightened out. you can do it, if you are handy with your hands and have the proper tools.
total labor should not go beyond 500 bucks, and that's already very generous.
good luck, po.Last edited by dr. d; June 10th, 2017 at 08:52 PM.
- Jun 2017
- 19
June 11th, 2017 02:18 PM #12Ah naalala ko may binili gasket maker si papa may ginamitan sya dati, ganitong nasa pic
If gasket maker gagamitin ko comparable ba sya sa traditional gaskets kung maatos lang pagkakalagay?
Sent from my BLN-L21 using Tsikot Forums mobile app
- Jun 2017
- 4
June 22nd, 2017 10:22 PM #13Hello po. I'm a newbie here. Magpapatulong po sana ako. I need your advices po. My car is a '95 Nissan Sentra Super Saloon (GA16 yung makina)
Recently, my car engine overheated. Naghahalo yung oil and tubig. Dinala ko sa isang car care shop, unang diagnosis was top overhaul lang. Tinanggal na nila yung cylinder head then sabi nila may linya na daw yung liners kaya ipapagawa na din sa machine shop. Pinaresurface yung cylinder head, pina grind yung crankshaft, nagpapalit ng sleeve, piston at piston rings, valve seals. Took a week bago nagawa, then kinabit na lahat, changed the oil. Nirelease na after days, pero sobrang usok kaya binalik ko then nakita na humahalo pa din. Ang ginawa na naman sa cylinder head is pina hydro test then wala naman nakitang crack, pero sabi nung mekaniko may nakita daw silang crack palitan na daw yung cylinder head. So yun, nagpalit kami ng surplus worth 16k. Pina overhaul din yung radiator.
Then ok na daw, hindi ko pa masyadong ginamit kasi mausok ng sobra pero dahil lang daw yun sa sinusunog yung bagong parts. I checked the radiator cap naghahalo pa din yung oil and water. Ang sinasabi ng mekaniko is may tama na naman daw yung cylinder head. Ang pinagbilhan ko nun is a credible dealer of car parts (CBROS) and kakilala namin so good one yung binigay. Ano po ba sa tingin nyo yung sira? Yung mekaniko kasi parang hindi naman talaga marunong pa. Gusto nya palit lang ng palit hindi nya naman nakikita kung ano talaga yung sira. Sorry po for the long post. Please help thanks a lot po!
Sent from my ASUS_T00J using Tsikot Forums mobile app
- Jul 2016
- 939
June 22nd, 2017 11:18 PM #14Tsk. Mahirap to wala sa harapan ko ung engine at di talaga makita. Pero kung tiwala ka na okay head mo, at sabi mo nga pinapalitan ng sleeve... Pag di magaling mag re-sleeve at mag deck ng block ung machine shop, pede lumubog ng kaunti sleeve enough to cause the sharon cuneta and smoke machine.
- Jun 2017
- 4
June 23rd, 2017 09:44 AM #15Chineck naman po nung mekaniko yung ilalam na makina wala naman daw po yung problema, yung head lang daw po. Hindi ko na din po alam tsk. Thank you po sa response
- Jun 2008
- 1,741
June 23rd, 2017 11:16 AM #16Mukhang pa swerte lang ang mekaniko mo. Hanap ka ng ibang mekaniko.
Sent from my NX549J using Tsikot Forums mobile app
- Jun 2017
- 19
June 26th, 2017 05:57 PM #17Yup try monkuna palitan mekaniko kung ano diagnosis. .medyo malaki nankasi nagastos nyo tapos di pa nasolvr problema. .baka nasa mekaniko problema
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
