Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Sep 2009
    Mag papa change oil po ako this oct. Gamit ko dati shell helix super,gusto ko po palitan sana ng brand and grade! Gusto ko po sana gamitin valvoline,ok lang ba gumamit lower viscosity grade gaya ng 15w-40? Honda accord 1997-98 po tsikot ko? Any other suggestions?
    much better if you can use the same viscosity, but of other brands. Mobil is a good brand, imho.
    Jun 2009
    helix super is 20w-50 and it is too thick for your engine.
    a 10w-40 or even a lower viscosity i think is much better for your accord.
    Sep 2009
    Quote Originally Posted by ramledi View Post
    Yun po kasi recomend sa manual. Nahihirapan kasi sya mag start-up pag malamig makina.
    May 2007
    Quote Originally Posted by joel_galvez2000 View Post
    10w-30 are ideal. I used 5w-20 on my accord. 20w-50 are way way way too much, you are not only wasting too much gas but makes your engine work's harder that it should. Trash out that oil...
    How about this Mobil Super 1000 15W 40 on the Ace hardware store cost only 805.00 / Gallon . It says for petrol ang Lpg car.
    Jun 2009
    joel,
    yun ang cause ng hard starting mo too thick kasi ang 20w-50
    much better na sundin mo suggestion ni v6dreamer
    speed,
    para sa akin bad ang experience ko sa mineral at semi syn ng mobil
    nung nag-adjust ako ng valve clearance nangitim ang rocker arm at iba pa.
    kaya balik ako sa helix plus
    joel,
    speed,
    anong car iyan bro? plan ko kasi mag mobil 10w-40 sa next oil change ko. btw, san ka nag-pa adkust ng mga valves mo?
    Sep 2009
    Quote Originally Posted by v6dreamer View Post
    Tnx bro! Bakit kaya yun ang recomended ng honda sa manual na 20w-50? Can you recomend any brand? Yun below 1k lang budget ko sa 4L na gagamitin ko po? Thanks!
    Jun 2009
    baludoy,
    sentra yung pinaggamitan ko ng mobil. may kapitbahay akong mekaniko hehehe
    joel,
    speed,
    paps gaano katagal ang change oil interval mo siguro kailangan mo mga 5000km at kung gusto mo malinis iyong sludge mga 3000km para malinis ng husto makina mo kasi kung matagal kang mag change oil nasusunog iyong langis pagnagiinit at nagiging tutong na maitim pag hindi mo pinalitan pero pag fully synthetic gamit mataas ang protection niya sa init kaya hindi nagtututong agad langis kahit sumobra ka sa recommended na 5000km. interval.
    meron ba ok na 10w 40 na oil na kahit semi synt lang na ok sa budget? Been using motul h100 for the longest time pero tipid mode na.
    Jun 2009
    speed,
    actually every 2500 to 3000 ako nagchachange oil sa mga sasakyan ko para parating feeling smooth ang takbo.
    maselan kasi ako kapag magaspang ang takbo.
    Nov 2007
    mga sir tanong lang po or any recommendation ng brand and level of viscosity for a '97 series 3 model ng nissan??
    balak ko kasi pa tune up at change oil at palit filters this november or december. baka po may mga suggestions kayu para mkatulong sa pag decide ko.
    Im currently using a shell motor oil, yung 'special' daw sabi nung gasoline boy.
    speed,
    Mas maganda nga iyong interval ng change oil mo dahil nandiyan ang buhay ng makina mo at tatagal ito basta alaga lang sa langis kahit hindi iyong mahal na langis basta 2500 to 3000 palit agad.
    Jun 2009
    gamit ko sa sentra ko helix plus 10w-40 mas lively ang makina kesa sa helix super 20w-50
    tune-up ng sentra is change spark plugs(ngk platinum bkre6gp) and air filter(oem) lang naman
    how much helix plus bro? semi synth? thanks!
    Sep 2009
    Boss,baka my ma-recommend ka brand ng oil filter besides VIC? Ok kaya ACdelco and Purolator? Yun kasi offer sa Rapide.
    sir joel, rapide ba kamo nagrecommend!? better check this thread...
    gamit ko is Petron Ultron Rallye 10W-40... ok naman. P1,500 all-in. VIC oil filter ang gamit.
    May 2008
    ako balak ko din ung valvoline next oil change...ok ba un?
    or mag stick na alng ako sa shell helix 10w-40 semi syn?
    lancer 2003 kotse ko...
help! oil change!
