Results 1 to 6 of 6
    Jun 2009
    napaoverhaul ko na ung carb ko.d ko lang malaman baket ganun pa din basta everytime na malamig ang makina pag start parang mamatay so kelangan sabayan mo ng rev para tumino ung rpm nya.minsan namamatay minsan d naman.but once na mainit wala ng problema sabe kasi pacheck ko daw ung ignition ko and vacuum hose.gusto ko muna masure bago ko dalhin sa casa
    May 2007
    Quote Originally Posted by arvinpogi View Post
    Tama. Palitan mo ang vacuum hose baka may mga singaw. Kung minsan mahirap makita ang crack dahil brittle na ang rubber.
    pwede rin smoke test to check for any intake leaks
    Jun 2009
    are you experiencing something like this...
    - cold start... crank
    - engine starts but like coughing (you need to pump gas pedal several times - engine may or may not die)
    - after a few pumps/seconds/minutes idle becomes normal even engine is not fully warmed up
    - all these happen regardless of how your idle and idle up was set and no matter what tune up you do
    gantong ganto po problem ko sir.
Help with my esi 94 d15b carb type hard starting when cold
