Results 1 to 6 of 6
    pwede rin smoke test to check for any intake leaks
    Jun 2009
    are you experiencing something like this...
    - cold start... crank
    - engine starts but like coughing (you need to pump gas pedal several times - engine may or may not die)
    - after a few pumps/seconds/minutes idle becomes normal even engine is not fully warmed up
    - all these happen regardless of how your idle and idle up was set and no matter what tune up you do
    gantong ganto po problem ko sir.
Help with my esi 94 d15b carb type hard starting when cold
