Results 1 to 10 of 14
- Feb 2004
- 138
June 4th, 2004 06:04 AM #1Mataas ang idling ng corolla gli ko..umaabot ng 1400 RPM pag wlang aircon. 1000 pag nakaengage ang compressor.
Chineck na ang mga hoses, OK naman.
Yung sikip ng cable na nakaconnect sa gas pedal, OK naman.
Ni reset na ang ECU by disconnecting the corresponding fuse.
Ano kaya dahilan nito? Sabi ng mekaniko, MAP sensor daw. Naghanap ako sa banawe, pota, 20K ang brandnew! :o hanap ng surplus, kaso di eksakto ang partnumbers. So bumili ako ng kahawig, medyo mas malaki lang, toyota MAP sensor din, 1K. Di rin umubra, mataas pa rin and idling!
HELP!!!
June 5th, 2004 04:26 PM #2
Baka OXYGEN sensor, pa check mo bandang pipe line bago mag primary muffler , pag may knock sensor ung EFI or ECU unit>>
- Feb 2003
- 44
June 15th, 2004 10:38 AM #4
walang O2 sensor ang 4AFE, ang malamang na prob mo ay yung aircon idle up switch (not the solenoid), eto yung nasa gitna ng firewall may parang knob sya to adjust the vacuum (big plastic knob kung Sanden, flat screw slot for Denso). Usually kung sira etong part nato magleleak ng vacuum pressure... Mas halata kung naka AC.
Medyo malabo masira ang MAF sensor ng 4AFE dahil nakatago sya sa may throttle body unlike sa Lancer na naka expose right after the air box.
Anong year ang Corolla mo? kung 93-94 Sanden yan, mga 2K ata bnew, kung Denso di ako sure but you can call Denso Coolmate at 8441493. Surplus medyo mahirap maghanap ng adjustable type, usually yung fixed sya (pang AE92) na walang adjustment, di pwede yun. Surplus mga 500-800 sya, akin dati surplus na Denso.
Try ko hanap pic
- Feb 2004
- 138
June 16th, 2004 03:03 AM #5Dinala ko sa banawe and tried swapping out the idle up a couple of times, i guess it was the switch since may flat screw na pihitan.. still, di bumaba ang rpm.
We also tried to replace the whole throttle assemby (twice pa) but the rpm was still at 1200-1400.
the mechanic then changed the distributor, same thing. he adjusted the alignment of the distributor, medyo bumaba but still at 1000 rpm...
im running out of ideas here...HELP
June 16th, 2004 09:47 AM #6
di mo pwede adjust ang idling ng Corolla, babalik ng ECU sa kung ano man data na natatangap nya through the different sensors in the car. Kung ako sayo bite the bullet and bring it to casa for a diagnosis...
June 16th, 2004 09:50 AM #7
Yung idle adjuster ng aircon is the one sa topmost center part ng pic na to, yung blue na kulay. Kung may leak yung hoses na yan magloloko ang idling.
http://www.pbase.com/image/2497290
- Mar 2004
- 652
June 16th, 2004 08:26 PM #8mr. freeman,
i think mr. theeved has a point. as i told you in one of this threads, ganyan din problem ng ride ko. 1400 rpm kung off ang a/c and 1000 pag naka-engage. Nangyari ito, as i remember, nabali ng mekaniko ang idle compensator and pinalitan ng replacement (di kagaya ng naka-litrato), ganito na ang labas, na mata-as ang rpm ng makina. di ko lang ma-asikaso ngayon kasi la ako sa pinas, kumakayod para me pampa-ayos ng oto.
The question I have is why not? Yes I recently bought CR1616 from Lazada, paid P58 and...
