Results 1 to 10 of 13
- Sep 2016
- 72
November 18th, 2016 09:39 AM #1I just recently replaced my head gasket a month ago but now i started to see green liquid again where the head gasket lies. My radiator coolant is slowly decreasing again., Do i need to consult a mechanic to tighten the cylinder head bolts? Any suggestions pls?
- Jun 2005
- 3,774
November 18th, 2016 09:57 AM #2Balik mo sa gumawa. Kailangan i-retorque yung bolts
Worst case, warped ang cylinder head ang needs machine shop to reface.
- Sep 2016
- 72
November 18th, 2016 10:16 AM #3
November 18th, 2016 10:28 AM #4
- Sep 2016
- 72
November 18th, 2016 10:38 AM #5
- Jun 2005
- 3,774
November 18th, 2016 10:43 AM #6Compressed na kasi yung gasket mo.
Either way, up to you kung gusto mo gamitin ulit. Di lang advisable. Backjob lang uli plus gagastos ka pa uli.
Alam ko sa ganyan top overhaul na.
- 54,207
November 18th, 2016 10:45 AM #7
- Sep 2016
- 72
November 18th, 2016 11:35 AM #8so i will tell the mechanic to have it machined? how long will it take to do all the job like machining?
- Jun 2005
- 3,774
November 18th, 2016 12:45 PM #9Yung recommendation should come fron your mechanic kung kailangan talaga after assessment.
Sa machine shop, expect downtime probably 3 days kung madami trabaho. Kung wala naman, kaya in a few hours.
Ano ba sasakyan mo?
- Oct 2009
- 2,271
November 18th, 2016 02:08 PM #10sa akin dinala ko ung head ng honda ko 8am tapos tinawagan ako 2 pm depende sa machine shop kung pag dating mo isasalang kaagad nila.or naka pila pa.dapat kasi pina machine shop mo na kaagad nung nag palit kayo ng HG.para lapat na lapat talaga siya.at siguradong walang singaw.
papalitan mo nadin ng valve seal.baka after 1 year eh umusok naman para atleast isang gawaan nalang.
Although I think good for 6 years naman normally ang tires, personally I will look for newer ones....
Finding the Best Tire for You
