Results 11 to 20 of 21
December 4th, 2008 02:26 AM #11
where can i find the location of the o2 sensor and what does it look like? sorry for the noob question.
December 4th, 2008 01:21 PM #12
In the exhaust, there should be one before the primary catalytic, and sometimes, there'll be one after. Just look for the wire leading to the exhaust.
December 5th, 2008 11:37 PM #13
niky,
thanks a lot bro, ill try to check the o2 sensor.a few days ago. i filled up with petron e10 with 95 octane, weird thing is the pinging went away for a few days until tonight.
December 6th, 2008 07:13 AM #14
Maybe it's an issue with your fuel tank? Fuel starvation on a low tank or a pump issue? What was the fuel level when it started pinging again?
December 6th, 2008 04:29 PM #15
i dont usually let the fuel level below 1/4.the pinging occurs occassionally whether at full tank or half tank, however i noticed that below the 1/2 mark the pinging occurs more often and when the car is driven for about over an hour in stop and go traffic traffic. in driving short distances and less traffic routes, i hardly notice any pinging.
December 6th, 2008 09:50 PM #16
Fuel pump or filter then? Might be that your fuel is getting too hot... You really ought to get a diagnosis at the casa...
December 7th, 2008 09:40 PM #17
^^will do sir niky, kaso saan ba ok magpa service na casa, ive had bad experiences na sa mga toyota casas, it took me 10 years din bago ako bumili ng toyota because of this. meron bang shops sa banawe area that are adept at checking?
December 26th, 2008 12:32 AM #18
follow up question, i remembered that i recently checked my plugs and let my mechanic put it back, maybe he didn't screw it tight enough...so:
1.can a loose sparkplug cause pinging?
2. if water is present in the fuel tank, can it also cause pinging?
December 31st, 2008 02:34 PM #19
Try to have a computer check on the engine, one probablity also is that the ignition timing may not be set to spec. What plugs are you running now? Did you try running colder plugs? Try also cleaning the sensors if needed (O2 and the intake sensor).
January 1st, 2009 12:44 PM #20
first thing i did after acquiring the unit was clean the intake sensor using spray on electrical contact cleaner. before cleaning i havent experienced any pinging sound, maybe i need to reset the ecu first? as i remembered i did not remove the battery cable when i did the cleaning.i just unplugged and plugged the intake sensor during cleaning.i havent got the chance to change the sparkplugs yet, its on stock plugs as of now.reg the 02 sensor i havent the slightest idea how to clean it as i dont know what it looks like hehehe
Latest mileage:
