Need some advise regarding the car I'm using, ayaw mag-start pag malamig. The problem first set-in when I went on an uphill then it suddenly lost power, it's as if it's being starved of fuel (I just had it gassed up), I pulled over and let the engine run, so it's running on idle, and dies when I press the gas pedal, btw, I'm outside the country and using a Proton Gen2 with EFI and drive-by-wire throttle control, pansin ko lang, pag inapakan ang gas namamatay, but if it's left on idle while the engine is hot, it keeps on running, release the clutch bit-by-bit then it starts rolling and sustains 1000rpm, it revs(without pressing the gas pedal) to 2,000-2500rpm when the clutch is pressed as it is sustaining 1000rpm when the engine is loaded, the next day when I tried starting it, ayaw na umandar, ano kaya problema nu'n?
. Thanks for the responses
