Results 11 to 20 of 33
- Aug 2008
- 15
January 13th, 2014 04:27 PM #11Pina pa chk ko sa kanila crankshaft sensor, although sa computer diagnostics walang sinasabing problema
- Sep 2013
- 44
January 13th, 2014 04:31 PM #12Baka naman nakahuyan na ng pyesa? Wag naman sana. Kumusta timing belt? Baka may bungi.
January 13th, 2014 05:19 PM #13
kung minsan sa casa mahirap din, pag wala na stored dtc (trouble codes) dead end na. parang hindi nila ma analyze ang live data.
January 13th, 2014 05:31 PM #14
Fuel and sparks lang iyan,- dapat putok na kahit palyado pa....One of them is definitely missing..... And then, trace back to source...
22.1K:nono:
- Aug 2008
- 15
January 13th, 2014 11:20 PM #15wala pong problema timing belt. gumaga piston at walang loss of compression. pina pa check ko crankshaft sensor kaso ngayon gabi pa daw nila papalitan, baka nga daw di na detect sa diagnostics nila. wala din problema HT wires, nakita ko nag s spark yung sparkplugs
- Sep 2011
- 262
January 13th, 2014 11:25 PM #16
- Aug 2008
- 15
January 15th, 2014 07:18 PM #17Gud pm Sir/Mam...double check na daw po lahat, wala parin. Nakikicoordinate na daw sila sa planta
January 15th, 2014 08:36 PM #18
Grabe, they cannot figure out what's wrong with a 10 year old car?
Casa people sometimes are like headless chickens.
- Nov 2009
- 3,484
January 15th, 2014 08:45 PM #19Casa's mostly operate with apprentice, maybe 2 or 1 are the only real mechanic that you wouldnt really call experts. They are only good reading codes and troubleshooting by the books. Those experienced and good mechanics were long gone working abroad. You'd sometimes better off with roadside talyer having more experience in troubleshooting.
TS, if you're suspecting immobilizer shutting your injectors then start working with the immobilizer. Possibilites are your computer got fried or needs reprogramming. Swapping parts could be the best way to check. Dalhin mo yan sa banawe, tapos na yan.
January 15th, 2014 09:22 PM #20
Xiaomi E-Car
