Results 1 to 20 of 33
    Jul 2006
    Grabe, they cannot figure out what's wrong with a 10 year old car?
    Casa people sometimes are like headless chickens.
    Casa's mostly operate with apprentice, maybe 2 or 1 are the only real mechanic that you wouldnt really call experts. They are only good reading codes and troubleshooting by the books. Those experienced and good mechanics were long gone working abroad. You'd sometimes better off with roadside talyer having more experience in troubleshooting.
    TS, if you're suspecting immobilizer shutting your injectors then start working with the immobilizer. Possibilites are your computer got fried or needs reprogramming. Swapping parts could be the best way to check. Dalhin mo yan sa banawe, tapos na yan.
    Nov 2007
    +100
    Toyota Marikina puros bagito nahawak sa sasakyan karamihan pa mga contractual parang sa dept store lang ang palitan ng tao.
    Baka nga sa banawe mahuli problema nyan
    hay naku ano naman kaya magagawa ng planta sa kaso na ito. share ko lang, last week I had a 2006 civic no start then galling casa, ang naging problema ay bad ground lang (the 12v supply sa crankshaft sensor ay dropping out, catched the glitch by oscilloscope).
    i'm not saying na yan problema ng civic nyo but it will help to check all powers and ground.
    Aug 2008
    noted po t2erns. tnx
    Aug 2008
    Sir meron po sila spare computer box and sensors. na try na daw nila i swap pero ayaw talaga, aside from that nakiki communicate daw yung computer ko sa computer nila.
    Quote Originally Posted by clei_torres View Post
    that's a good indication that the issue is more likely a wiring issue (power and grounds as I posted earlier)
    in my case IIRC it's the ground G101 (hidden beside the throttle body), that ground supplied the ground for the pcm, being intermittent the pcm loses power momentarily. that's the reason the ground supplied by the computer to the coil side of the pgmfi relay is also lost and that will skew the readings of the sensors like crankshaft position sensor and thus the no start condition. the glitch is very intermittent and very fast that no digital tester can catch (I used oscilloscope to catch the glitch).
    Aug 2008
    Quote Originally Posted by t2erns View Post
    Sir na quote ko napo yung message nyo sa SA ko, ang sagot sakin na check na namin, update nalang daw po ako kung umandar na kotse...ewa ko ba kung ano pa gagawin nila
    Jan 2014
    Pa F1 naman po ako
    Meron po akong problema sa mitsu El carburetor type kapag coldstart po kasi in the morning pag start mamamatay din agad unless sabayan mo ng acceleration ano po kaya pinaka possibleng problema ng itlog ko mga sir's please pa F1 po ako tnx more power sa lahat ng may itlog
    binalikan ko yung first post nyo, bago nasira alternator maayos naman andar ng car? how about the alternator, original ba ang pinalit? may ginawa ba conversion sa wiring ng alternator? na try na ba paandarin na tanggal ang wiring ng alternator?
Help: Engine crank but fails to start
