Results 1 to 3 of 3
- Jun 2010
- 35
August 31st, 2010 03:08 PM #1mga sir and ma'am, i have a problem, last sunday natuyuan po ako ng gasolina(which is bad daw po) after refiling, i observed that my fuel consumption became 4-5 km per liter pero no jerking or erratic idling . dati po nasa around 6-8km/liter, is this a carb problem only or there are other parts need to fix or to tune?how much naman po kaya aabutin to fix my problem?
a month ago i also observe na while the engine is running amoy gasoline tambutso ko pero clear naman wala naman usok or kung meron man super minimal lang.
kaka change oil ko lang po last 2 weeks. di pa ako nakakapag pa tune-up.
ang car po eh Daewoo Racer Gte 1996 model, carb, Manual transition
- Apr 2009
- 1,902
August 31st, 2010 06:13 PM #2Check your fuel filter (replace as needed, mura lang ito).
Dirty carburator jets can cause choking as well, kaya pa-check na din then clean as needed.
I just clean my carb DIY but in your case, better see a carb mechanic.
- Jun 2010
- 35
September 2nd, 2010 04:27 PM #3ah ok, thanks po, so no major problem naman pala sana maayos din pati fuel consumption ko sana maging ok din.
of course! the former was more enlightening than reading the Holy Book. mom loved the Ten...
Traffic!
