Hello Tsikot,
GUYS HELP ME SOLVE THIS PROBLEM? MYSTERY of the gastanks ive used for an ae92:![]()
Hi! Ive had this problem and it seems that I havent solved this mystery with my ae92. Take note im on my 5th tank. (YES YOU HAVE READ CORRECTLY 5th!) Here is the history: My vehicle is an ae92 w/ a 4a-fe engine, so basically i had to source out an efi tank since the local ones are just carbureated fuel tanks. Inside a carbureated tank there are dividers and using a carbureated type fuel tank causes the engine to fuel starve. So 1st tank, my stock carbureated upgraded to my 2nd tank, an efi ae92 tank and efi pump i used for my car to avoid fuel starving. After like a year tumulo from underneath. Couldnt figure out why basta ang culprit SAYAD as per mechanics. Geeesh di naman gaano ka lowered car ko. So ok lang sourced another manual carbureated fuel tank. Kinabit yung 3rd tank. After like months sayad na naman at tagas. Bought another efi tank so pang 4th na to. Ok naman tumagal for a year. Around 3 months ago, tumagas na naman yung efi tank and resorted to another carbureated fuel tank w/c is the fifth. For crying out loud Ive had 5 tanks already. Also take note, under the fuel tank we placed like a rubber mat to insulate the hull from being scratched around the 3rd tank we used. But still nagleleak pa rin.
To recap: Manual stock carb (1st) then to EFI tank (2nd) then to manual carb (3rd) then to EFI tank again (4th) and currently back to manual carb (5th).
Ive talked to a couple of people and here are their theories explanations:
1) Fuel I use - im using just regular unleaded fuel na may ethanol (recently changed to premium which i think is better than unleaded.
2) Rear shock absorbers - baka daw nagbobottom out yung rear shocks ko (BTW im Using TEMS for the rears ng ae 92 ko Toyota Elec . Modulated Suspension) had this checked ok naman rear shocks ko.
3) Baradong Charcoal canister - already removed this around the 3rd tank I used.
4) Baka daw baliktad fuel lines ng return hose and young breather hose which I douubt and had it checked by a reputable mechanic.
In the 5 tanks Ive used the prevailing factor kung bakit nabubutas fuel tanks ko is gasgas na may sumisiret na pinhole na gasolina. I seem to not solve this problem. Well sana di na umulit tong problema ko.
Any inputs on this matter will be highly appreciated. Thanks!![]()
