Results 1 to 8 of 8
    Apr 2008
    mga bossing, question po... ung 2000 gas revo ko pag start mu ung makina, ok naman ung RPM nya, nasa 9 b un? pero pag on mu n ung aircon e bumababa hanggang 2 ung RPM nya, hanggang sa parang mamamatay na ung makina kung hindi ko aapakan ung gas. salamat po sa mga inputs!
    check you idling speed.
    check your battery, baka mahina na. aircon takes it electricity from the battery, not from the alternator. check mu din alternator, baka mahina karga.
    pero if di naman namamatay ng tuluyan, baka low idle lang
    Oct 2009
    If the MIL (malfunction Indicator Lamp) or sometimes they call it CEL (check engine light) does not illuminate, your most likely problem would be a sticking Idle Motor Actuator (this controls you idle speed when you turn on you a/c, or stabilizes your idle speed whenever the computer detects from you a/c, p/s, headlamp.
    Oct 2009
    Quote Originally Posted by aejhayl17 View Post
    Pardon me, but this is hard to let go. All electrical loads when the engine is running will come from the alternator, provided the alternator can supply the demand, when the demand exceeds the supply they battery will provide it.
    His vehicle is is a 2000 Revo with EFI engine, the computer manages the engine idle.
    ito ang pagkakaintindi ko sa revo and other efi cars.
    initial during engine initial start (engine cold) approx. 1300rpm
    gradually will stabilized to 650rpm
    no load approx 650 rpm
    load will increase by demand (brake, electrical)
    by approx 150rpm
    load will increase to approx. 850rpm
    when a/c is selected to on
    thru idle up.
    check mo muna ang throttle mo baka madumi na,
    baka bara na ang mga ports sa loob
    then check ang mga vacuum hose for leak .
    then check ang idle up baka di na gumagana replace mo na
    Jan 2010
    Sirs, ask ko lang po; yung grand vitara 2.7 v6, ok ang idle, ok response pag tapakan selenyador; pero pag nilagay sa reverse or drive (a/t po), bumababa idle hangang mamatay.. would appreciate your opinions po kung anu sa tingin nyo problema, at kung ano solution? Many thanks in advance po..
    Its the Idle Air Controller Valve/servo in most cases. Have it checked . .
    Jan 2010
    Sir mazingerZ, many thanks po for your comment.
bumababa ang RPM
