Results 1 to 7 of 7
- Dec 2006
- 273
December 9th, 2010 08:14 PM #1Hello engine gurus;
I need your ideas / techniques on how to remove the harmonic balancer / crankshaft pulley from the engine without using a puller.....
Thanks in advance....
- Dec 2006
- 273
December 10th, 2010 04:25 PM #5
This is my harmonic balancer puller now. However before I got these we use to DIY some 3/8" flat bars ( sometimes even two on top of each other for added strenght ) and drill holes for use as makeshift pullers.
December 11th, 2010 07:47 AM #6
Kung crankshaft pulley, madali lang yan. isandal mo wrench sa chassis then pitikin starter.
or use a chain wrench around the pulley (with cloth wrapped around the pulley) to hold the pulley.
kung harmonic balancer sprocket, usually puller na yan kung hindi matanggal. but you can try 2 big ang long flat screwdrivers.
- Dec 2006
- 273
Kanina result Ng nag settled sa 900 nag turn ako Naircon nag dropped Minsan umaangat sir pero kapag...
LANCER Itlog (93-96) Owners - Please Post Here!
