Results 1 to 7 of 7
    Hello engine gurus;
    I need your ideas / techniques on how to remove the harmonic balancer / crankshaft pulley from the engine without using a puller.....
    Thanks in advance....
    i think you can't, it's pressed fitted.
    Oct 2007
    Bro what vehicle po ito?
    Quote Originally Posted by JayL View Post
    Vanette po ito. Z20 engine.
    Oct 2007
    This is my harmonic balancer puller now. However before I got these we use to DIY some 3/8" flat bars ( sometimes even two on top of each other for added strenght ) and drill holes for use as makeshift pullers.
    May 2009
    Kung crankshaft pulley, madali lang yan. isandal mo wrench sa chassis then pitikin starter.
    or use a chain wrench around the pulley (with cloth wrapped around the pulley) to hold the pulley.
    kung harmonic balancer sprocket, usually puller na yan kung hindi matanggal. but you can try 2 big ang long flat screwdrivers.
    Salamat sa mga suggestions ninyo, I'll try them all.
Harmonic balancer / Crankshaft pulley
