Results 1 to 10 of 10
    Aug 2003
    mga peeps what should i check pag hard starting na? Pajero ride ko po.... :confused:
    thanks!
    The glow plugs. Number 1 suspect. Hehehehe.
    battery
    glowplug
    starter
    worst...compression problem na...
    battery. number 2 suspect.
    battery..
    pero kung ok pa battery..
    maybe alternator..
    All of the above.
    usually glow plugs lang yan.
    Mar 2003
    at first glance, i wud suspect na glow plugs nga ang may problem. ano ba model ng pajero mo? ang gnagawa ko kac dati sa gen1 namin dati nung naluma na ay maski green na yung pre-heat lamp, i still wait for 5 mor seconds bago ko start. 1 click lang yun, pero if i start d car as soon as d pre-heat lamp turns green, d yun aandar. ewan ko lang if my technique wud apply to the gen2 models though
    I hate to say the injection pump or injectors, but it's possible.
    After checking all of the above, check the fuel injection system.
    Sa Injectors:
    1. It's already defective.
    2. Spray pattern is really bad.
    3. Worst, it doesn't spray anymore.
    Injection pump:
    1. The pre-filter is clogged up.
    2. The rotorhead [for rotary pumps] is already worn out. This gives the fuel the pressure it needs to be injected sa engine.
    Doc Diesel
    baka leak sa fuel line, may air bubbles na nahihigop sa butas o leak kaya nawawalan ng pressure sa injection pump,
    kung naistart mo na ba mahirap ba na istart uli pagkatapos mong patayin? kung mahirap injection pump as doc diesel said
hard starting
