Results 11 to 20 of 111
December 29th, 2011 05:53 PM #11
I've read 10w30 is more commonly used for the Honda City iDSi, anyone who can recommend which is better? 10w40 or 10w30?
*umi001
Thanks for the tip, mas OK sana if they had 10w40 or 10w30!
December 29th, 2011 06:06 PM #12
If manula says 10w30 then better to use that But since we have a tropical temp, a 10w40 won't be a problem as well.
You may follow the advice that Idemitsu 5w30 is ok IMO.Fasten your seatbelt! Or else... Driven To Thrill!
December 29th, 2011 06:33 PM #13
- Aug 2008
- 965
December 29th, 2011 07:28 PM #15
December 29th, 2011 07:46 PM #16
December 29th, 2011 10:13 PM #17
Nagpa change oil ako ng Idemitsu Extreme Eco 5w30 * 1.3k 4L sa Unioil(official distributor) then dinala ko sa trusted mechanic ko for my 40tkm pms. So far ang mga napansin ko, mas tahimik ngayon makina halos di ko na madinig sa sobrang tahimik hehe at halos wala din vibration sa dashboard at manibela compared sa dati kong oil which is shell helix mineral yung dilaw almost 1k ang 4L. Pansin ko mas tumipid din sa konsumo ng gas. Leading lubricant ang Idemitsu sa Japan at gamit ng ibat ibang casa like toyota honda mercedes pati ata mazda at nissan. Di naman siguro gagamitin ng honda toyota mercedes etc ito as their oem oil kung di ito "kahit papano" ay ok :D
Mura pa.
December 29th, 2011 10:13 PM #18
from what I remember sa manual ng Honda from 0W30 to 10W40 and everything in between pwede gamitin. wala naman naksulat na mas masmaganda one over the others.
pwede na yun change oil promo nila..makakatipid ka talaga. kahit 3X a year or 4X a year ka papalit sulit pa rin 1k lang all in (oil, filter and labor).
December 30th, 2011 12:43 AM #19
high idle RPM at engine start
