Quote Originally Posted by userfriendly View Post
Dont know how much you will need. I use Petron coolant for my car. Instruction says mix 500 ml petron green coolant with 1.5 liters of distilled water (3:1). So it will give you 2 liters. I think 4 liters of the mixed stuff should be enough. Petron coolant is about 125 pesos from Pertron gas stations.
Toyota sells premixed pink coolant. It comes in 2 liter bottles. Less than 200 a bottle.
Preston is also good for your car. They have both concentrate and premixed versions. Cant remember how much.
i see, thank you sir!!
will try na lang muna petron mixed with distilled water, since katabi lang namin station
sir ask ko na din po,in preparing the solution,what needs to be put first?tama po ba procedure na gagawin ko?pls evaluate:
  1. drain the radiator solution from the drain plug under
  2. put the 1 part solution(if will use the petron coolant)
  3. put the 3 parts distilled water
  4. refill the coolant tank reservoir with distilled water
Sir,if i will DIY,how will i remove the residue or sludge if there's any in the tank?
thank you!
