Quote Originally Posted by tukong View Post
Anong Brand Ng Gear Oil Na Ma Reccomend Nyo Sir Otep For Fuego
4wd or 2wd? sa 4wd limited slip rear diffs so you need LS rated gear oils. sa d-max the same rin may LSD pag 4wd, check lang sa mga 2wd if LSD rin, if you will not be using the correct gear oil the friction plates will be damaged.
