Results 1 to 9 of 9
- May 2017
- 7
July 30th, 2017 07:07 PM #1Hi guys help po. Newbie driver, car owner and tsikoteer here. When I start my car there's this gas smell, rpm spikes at 1500 and then gradually falls down to 800 after 12-15 mins. I only smell the gas when starting the car. Any idea what the problem is? My car is avanza 07 MT 1.5 G.
- Jul 2017
- 1
July 31st, 2017 01:58 AM #2
- 54,289
July 31st, 2017 02:01 AM #3
July 31st, 2017 03:38 AM #4
possibly the fuel filter is clogged. or the exhaust manifold has a leak. or a gasket leak.
- May 2011
- 481
July 31st, 2017 07:32 AM #5
your catalytic converter was still cold and was not scrubbing the exhaust fumes yet.
it takes around 1200 up to 1600 degrees fahrenheit for it to work. when the engine is first started, it is dead cold and of course, the exhaust smells like that of the cars of the "70"s and earlier.
totally normal
July 31st, 2017 07:46 AM #6
Nobody seemed to ask the question where the fumes are being detected (ie. outside in the engine bay, exhaust, or near where the gas tank is, or is it coming from inside the passenger cabin?) Also, whether if it's raw, unburned gasoline or if it's exhaust fumes.
Further troubleshooting depends on answers to these questions.
- Nov 2008
- 641
July 31st, 2017 09:41 AM #7This is totally normal. The smell comes from the exhaust fumes during cold starts, then disappears or normalizes once the engine meets the optimum temp. Question, do you park your car facing backwards (Your front facing the gate)? If that is the case, try parking facing the front. This will lessen the smell during cold start.
- May 2017
- 7
August 3rd, 2017 02:35 PM #8
- May 2011
- 481
August 8th, 2017 02:54 PM #9
They replaced it with flashing green light prior to turning yellow. I guess it simplifies things?...
SC (temporarily) stops NCAP
