Results 1 to 9 of 9
    May 2017
    Hi guys help po. Newbie driver, car owner and tsikoteer here. When I start my car there's this gas smell, rpm spikes at 1500 and then gradually falls down to 800 after 12-15 mins. I only smell the gas when starting the car. Any idea what the problem is? My car is avanza 07 MT 1.5 G.
    Jul 2017
    Quote Originally Posted by CCi View Post
    have experienced the same cannot believe its hapoening for im using a year old car.it bothers me everytime being a new driver especially that i am taking a long drive almost everyday.
    try shifting to another fuel brand.
    in my old (non-toyota) car, the odor of gasoline was stronger when i used ptt.
    possibly the fuel filter is clogged. or the exhaust manifold has a leak. or a gasket leak.
    May 2011
    your catalytic converter was still cold and was not scrubbing the exhaust fumes yet.
    it takes around 1200 up to 1600 degrees fahrenheit for it to work. when the engine is first started, it is dead cold and of course, the exhaust smells like that of the cars of the "70"s and earlier.
    totally normal
    Jan 2009
    Nobody seemed to ask the question where the fumes are being detected (ie. outside in the engine bay, exhaust, or near where the gas tank is, or is it coming from inside the passenger cabin?) Also, whether if it's raw, unburned gasoline or if it's exhaust fumes.
    Further troubleshooting depends on answers to these questions.
    May 2017
    I can smell it from inside and once I'm outside about 1 meter away. It smells like unburned gas and lingers for about 1-2 mins then fades away. I don't see any leak under the car. Gasket cap is clean.
    May 2011
    If the raw fuel was coming from somewhere else other than the exhaust, you'd be able to smell it even with the engine off or the engine warm.
    This is totally normal. The smell comes from the exhaust fumes during cold starts, then disappears or normalizes once the engine meets the optimum temp. Question, do you park your car facing backwards (Your front facing the gate)? If that is the case, try parking facing the front. This will lessen the smell during cold start.
Gas smells when starting, high rpm
