Yeah. That equipment is a new motor.
You can't run a gasoline engine on diesel. You can convert it to diesel by changing out the entire fuel system, welding the holes in the cylinder head shut, changing out the pistons for high compression ones (gasoline compression is usually 9:1 to 11:1. Diesel is ariound 22:1 if you don't have a turbo), changing the connecting rods for stronger ones to take the extra pressure, reinforcing the engine block, changing the camshaft grind, etcetera.
That kind of work on an engine will cost you more than the car is worth. To swap in a diesel engine, instead, will cost you some 100k pesos. To simply sell your car and buy a diesel car which already has the correct transmission, gauges and tank will cost even less.
