Results 1 to 17 of 17
    i own a honda city idsi 03, ayaw na magstart ng engine, pero ok naman yung battery, fuel pump problem daw sabi ng mekaniko sa kanto, pero dinala ko na sa casa to be safe....pero magkano kaya ang fue pump, and what causes its malfunctioning?
    Oct 2005
    Quote Originally Posted by gangley View Post
    if you don't hear the 3 seconds hum when you put the key on start (not ignition) then your pump is busted. But if you can still hear it have it checked using a pressure guage. Usually nasa above dapat 35PSI yung reading. pag mababa na pressure palit na.
    ang cause ng premature wear/malfunction ng pump is when you dont regularly change your fuel filter and allow less than 1/4 of fuel sa gastank.
fuel pump ba?
