Results 1 to 9 of 9
- Mar 2013
- 35
August 6th, 2016 03:25 PM #1Meron po bang nagchecheck ng ganito satin? Para malaman sana kung sira yung fuel pump or may bara lang? Kumakadyot kasi yung sakin tapos bumababa bigla yung rpm tapos balik sa normal..parang tinanggalan ng gas tapos balik uli sa normal..pero may position lang sa gas pedal na nagkakaganun siya. Lancer pizza 2001 matic po.
- Aug 2012
- 2,767
August 6th, 2016 04:25 PM #2If you have OBD2 port, you can try ELM327 Bluetooth OBD2 Scanner. Use Torque app to show fuel pressure.
Sent from my D5833 using Tapatalk
- Aug 2012
- 2,767
August 6th, 2016 04:49 PM #4
di ba sakit ng lancer yan and usually sa maf sensor or madumi ang throttle body.
- Jul 2016
- 939
August 7th, 2016 01:17 AM #5Walang fuel pressure sensor ang 2001 lancer. Kahit nga 2016 model na lancer wala rin. Fuel pump usually namamatay na makina or ayaw na mag rev/pumower... If may certain na apak lang kamo na sinisinok, baka TPS sensor. Try mo tangalin TPS socket then check mo if mawala sinok. Pede rin MAF. Tangalin mo lang din maf socket then check kung maging okay takbo.
- Aug 2012
- 2,767
August 7th, 2016 12:00 PM #6Sorry, no fuel sensor pala ang Lancer 2001. But anways, you can use OBD2 scanner to scan engine error codes and monitor other sensors.
- Mar 2013
- 35
August 8th, 2016 04:25 PM #8ahhh di pala machecheck fuel pressure nito. salamat mga sir!
try ko check ang TPS..sana naman dun lang problema at hindi sira TPS.
nalinis ko na maf sensor at napalinis ko na throttle body eh,walang pinagbago.
machecheck parin ba error codes nun kahit hindi laging nakailaw ang check engine indicator? minsan umiilaw siya kasabay ng pagkadyot pero sobrang madalang eh.
- Jul 2016
- 939
August 8th, 2016 08:18 PM #9
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
