Results 1 to 9 of 9
    Mar 2013
    Meron po bang nagchecheck ng ganito satin? Para malaman sana kung sira yung fuel pump or may bara lang? Kumakadyot kasi yung sakin tapos bumababa bigla yung rpm tapos balik sa normal..parang tinanggalan ng gas tapos balik uli sa normal..pero may position lang sa gas pedal na nagkakaganun siya. Lancer pizza 2001 matic po.
    Aug 2012
    If you have OBD2 port, you can try ELM327 Bluetooth OBD2 Scanner. Use Torque app to show fuel pressure.
    Sent from my D5833 using Tapatalk
    Aug 2012
    di ba sakit ng lancer yan and usually sa maf sensor or madumi ang throttle body.
    Jul 2016
    Quote Originally Posted by red_one View Post
    Walang fuel pressure sensor ang 2001 lancer. Kahit nga 2016 model na lancer wala rin. Fuel pump usually namamatay na makina or ayaw na mag rev/pumower... If may certain na apak lang kamo na sinisinok, baka TPS sensor. Try mo tangalin TPS socket then check mo if mawala sinok. Pede rin MAF. Tangalin mo lang din maf socket then check kung maging okay takbo.
    Aug 2012
    Sorry, no fuel sensor pala ang Lancer 2001. But anways, you can use OBD2 scanner to scan engine error codes and monitor other sensors.
    Aug 2004
    I agree with Yebo on this:
    From experience, problems like that on that gen of Lancer can be traced to the MAF sensor or throttle.
    Mar 2013
    ahhh di pala machecheck fuel pressure nito. salamat mga sir!
    try ko check ang TPS..sana naman dun lang problema at hindi sira TPS.
    nalinis ko na maf sensor at napalinis ko na throttle body eh,walang pinagbago.
    machecheck parin ba error codes nun kahit hindi laging nakailaw ang check engine indicator? minsan umiilaw siya kasabay ng pagkadyot pero sobrang madalang eh.
    Jul 2016
    Quote Originally Posted by haxso View Post
    Macheck naman fuel press by using mech. gauges i hook up sa fuel line mo.
    Yes, masave pa yun sa memory ng ecu wag mo lang tangaling battery.. BTW, since 01 model.. Di ko rin sure kung may OBD2 port na sya.. Sana meron na...
Fuel pressure test
