Results 1 to 17 of 17
    Mga Papi,
    My father-in-law's pathfinder pickup just recently had its injectors recalibrated. Parang it is done once every x number of years daw as part of regular servicing.
    Now my question, how about the injectors for EFI gasoline engines? One mechanic told me before that it is not needed for gasoline engine vehicles. The ECU takes care of the spray quantity coming from the injectors. Hence, it does not need to be serviced, unless kung talagang may tama.
    Out of curiousity lang pmga papi, could someone please elaborate on this?
    Thanks.
    Aug 2004
    Basically. All you need to do with gasoline injectors is to check that they're not plugged. But there's no need to calibrate them. You can have them balanced, though, for better response and power. But it's not necessary.
    the injectors are just checked to ensure that there are no blockages and the fuel feed is at optimals.
    Jul 2006
    How do you calibrate injectors? I know they're "pop tested" to ensure balanced atomization of the spray, as well as spraying at the correct pressure. Maybe that's just the general term for those two combined?
    I think gasoline EFI injectors are replaced once orifice spray and hole is more than it should or solenoid malfunction occurs.
    Most diesel injectors can be serviced. There are lots of good quality replacement parts as well as OEM parts. That is what is nice about diesel engines and their fuel systems even old units can serviced as long you have the serial numbers and control parts list.
    Its also important that you bring your injection pump, common rail pump and injectors whether mechanical or electronic to a shop who has exact information for that with an accurate test bench for optimal power and fuel efficiency. In diesels guess work is considered a no no.
    May 2007
    Calibration no, cleanning yes.
    Fuel injection is a small engine part that inject fuel where its need to go. Cleanning your injector yearly makes your car run properly and better gas mileage. Injector cleaner is available at your auto parts supply or gas station (do it yourself) that can pour in your gas tank. Another is to remove the injector and have it professionally service and cleaned. This is a time consuming and more expensive (again professionally wag sa tabi tabi), but it can be the best injector cleanning process, dont forget to replaced your fuel filter also.
    Sep 2006
    Quote Originally Posted by mbeige View Post
    Kamusta ka? Are you back in the US?
    Calibration of regular mechanical diesel injectors entail the following:
    1. Making sure that the correct nozzles & parts are installed
    2. Adjusting the opening pressure (pop off) to specs.
    3. Checking nozzle chatter / automization, spray angle & hole/s condition.
    4. Checking fuel back-leakage
    5. And checking for external leaks
    Jul 2006
    Hi Jake,
    Yes I'm already back, sorry I wasn't able to drop by your shop. Had too much stuff going on.
    During calibration, I wonder, is it standard procedure to clean the prechambers too? I'm not familiar with direct injection engines so I only ask for the IDI type
    mbeige,
    This are the type of trucks Sir Jake repairs. You may be familiar with it there its a Freightliner with a C12 CAT engine. He is also good in Cummins DD and anything diesel that he has complete information on it. I consider his shop the PGH (Philippine General Hospital) of injection pumps cause i see severely damaged, disassembled, incomplete and mis calibrated injection pumps and injectors yet they bring it back to life
    Jul 2006
    Looks like I really missed a lot! The main reason I became a dieselhead was my W123 300D-T. There was some talk about upgrading the injector nozzles to Bosio types. Didn't read much on it since baka mapagastos lang ako hehe
    edit: I remember those trucks. I know the headlamps look different, the ones here resemble the headlamps from a W126, with the rhomboid shaped main lens but those have sealed beams (?).
    Sep 2006
    Hi Jake,
    We don't normally touch the prechambers. This is not a problem area.
    Replacement of the compression washers between the between the injector and prechamber is mandatory on 617s and 60xx engines.
    Jul 2006
    Thanks Jake, I was going to ask about the washers. You read my mind
    Aug 2004
    Oops... posted wrong... finally remembered what they called it... blueprinting. This is where they ensure that each injector gives the exact same amount of fuel and has the exact same spray pattern. Great for tuning for power, but too expensive to make sense otherwise.
    May 2008
    Please see my message below... thanks.....
    May 2008
    My 13 year old Corolla 95 GLi is already running on low mileage 9km/L (is this really low or normal?). Is it advisable to have the injection system cleaned? How much would it cost me? Is there a recommended shop in Alabang? Thanks!
    My odometer reading is already 120,000+ km.
    Sep 2006
    My 13 year old Corolla 95 GLi is already running on low mileage 9km/L (is this really low or normal?. 9kms/L is not bad for city driving.
    Is it advisable to have the injection system cleaned? How much would it cost me? Is there a recommended shop in Alabang? Dasher Goodyear Servitek is a great workshop located in Alabang. Replace your air filter, and have a thorough engine tune-up. They can recommend if injector service is necessary.
    May 2008
    Thank you sir Dieseldude.
Fuel Injector Question
