Results 1 to 15 of 15
    Jan 2011
    pwede po ba i tune up ang galant mpi 89 model? EFI engine? palyado kasi makina ko, parang kobota ang tunog
    Sep 2006
    Yup lahat naman ng kotse puwede tune up.
    Jan 2011
    syempre naman. at kailangan ang periodic tune up.
    Jan 2011
    http://i1178.photobucket.com/albums/...psbd063711.jpg dinala ko sa talyer hinde daw na tutune up ito makina nya
    Feb 2009
    Quote Originally Posted by slowrockmusic View Post
    kaya pala, dinala mo sa talyer. di ba ang talyer pagawaan ng kalesa?
    Jan 2011
    hahah badtrip nga ako pinihit nya lang distributor ko na tune up na daw, nag self adjust na daw,binuksan nya cylinder head wala sya makitang pinipihit kaya hinde daw na tutune up
    Feb 2009
    cheap service does not always translate to good service. take it to a qualified service technician. don't be so impressed though, if the shop appears to be well equipped, tools and equipment does mean the technician is trained and experienced.
    now back to the misfire. check which cylinder is uncooperative by unplugging the spark plug wire from the distributor cap with a plastic fuse puller pliers if you are allergic to high voltage spikes and note which cylinder does not cause a change in engine rpm when deactivated. then differentiate whether the misfire is caused by mechanical condition, ignition or fuel ignition.
    what year is this mitsubishi corolla?
    Jan 2011
    Mitsu Galant MPI 1989 EFI engine wala daw pinipihit para ma adjust ang valve clearance kaya nag seself adjust na daw ito engine http://i1178.photobucket.com/albums/...psbd063711.jpg
    1. Compression test
    2. Check/Change spark plugs
    3. Check and replace fuel and air filters if necessary
    4. Check ignition system (distributor, HT wires)
    5. Clean the intake plenum and check the servo if it's still functioning well.
    6. Check timing (with a timing light).
    Have a reputable shop do the work.
    Jul 2006
    1. Compression test
    Plus 1 ..........
    Jan 2011
    1. Compression test
    7. TB should be cleaned as well. pag marumi, daming problema.
    Dec 2008
    sir +1 to sir vinj and shelu..
    self adjust po talaga makina ng mpi galant.
    just bring your car sa mga expert sa efi.
    Feb 2012
    1. Compression test
    hi sir... may alam ka ba reputable shop para mag tune up ng corolla xl lovelife ko?? gusto ko ipaset ang ignition system at syempre gusto ko yung meron nung sinabi mo (with a timing light) manila to qc area sana.. maraming salamat
    Quote Originally Posted by rrck0228 View Post
    Boss try any servitek, they have the tools and equipment. Pero not all servitek have good mechanic try them timing light and compre test would cost you around 1.5k petot
    Feb 2012
    Quote Originally Posted by brainmafia_310 View Post
    thanks for that info ser.. ok lang na di gano magaling mekaniko as long as kumpleto ang gamit maitatama ang timing
TUNE UP Question
