Mga bro,
Balak ko kasi mag-palit ng fuel filter saan ba banda' matatagpuan yon? Pasensya na kelangan ko kasing matuto ng konti sa masters natin dyan![]()
Mga bro,
it will be better if you will also post your car/truck for specifics...=)
Sir Beetols / Antonmace,Originally Posted by antonmace
It was a an surplus engine i think 80's model pa ito >ISUZU GEMINI 4FB1.naka mount sa assembled wrangler.
Sundan mo lang ang fuel line either from the tank or from the injection pump. Check mo sa gallery ko kung may picture ng fuel filter. Usually canister-type siya with a hand pump on top.
Meron ding in-line (nasa fuel line mismo) na fuel filter. usually cylindrical ito and semi-transparent.
Pero ang mahirap sa assembled vehicle, baka hindi ito ikinabit ng assembler mo. Goodluck searching.
how long po ba bago dapat palitan yung fuel filter for diesel engine (2B landcruiser)?
thanks.
Originally Posted by mcbry
depends on the quality of diesel you use. i also have a surplus engine sa minicruiser ko and I usually change the fuel filter once a year pero if i had money i change it every 6 months kasabay ng palit ng oil, oil filter at air filter para swabe![]()
FYI lang. I just replaced Fuel Filter of my FieldMaster last Saturday as I'm having difficulty getting it started in the morning. Big improvement on cold start response, its now more responsive when accelerating. For my ride, it is recommended to be replaced every 10K km.
Sir Otep,Originally Posted by OTEP
"Usually canister-type siya with a hand pump on top." Ito po ba yung handpump na pag-natutuyuan ng diesel e dito binobomba para lumabas yung hangin![]()
Another question... what are the feedbacks on using OEM vs. replacement canister filters? Any recommended brand? My dilemma now is i want to change every 10,000m vs. every 20,000km that is recommended by the manual but the Frontier uses two fuel filters and it's quite pricey for the OEM (sets me back around 4K).
What then is more adviseable?
1. Status Quo: Change every 20,000km and stick to the OEM fuel filter
2. Change every 10,000km but employ a replacement brand.
samson,
Yes, yung binobomba na may parang metal can sa ilalim. Yun ang filter na attached sa pump.
vinj,
I've had good results using ViC fuel-filters. They cost around Php 600.00/canister.
yup yup yung may binobombahan...mukha rin syang oil filter...tignan mo kung may mga numbers na parang sa oil filter.
BEWARE...pag matagal mo ng hindi pinapalitan yung fuel filter..bigla nalang mabubutas ito..dahil sa dumi and water accumalation sa baba ng filter...nangyari na sa fren ko.
parang ganito...
parang air filter din yan...pag pinalitan mo makaka hinga na mahusay ang tsikot...hehe...parang babalik ang power nya
Ibig bang sabihin pag-nagpalit ako nyan e' buong assembly??? na katulad ng nasa picz ni Sir Jeepcruizerph, O may babaklasin lang ako dyan para makuha ko yung filter sa loob![]()
You just unscrew the canister under the pump. Then, kapag nakuha mo na yung canister, you unscrew the plastic thingie under it. You buy a new filter and put the plastic thing on it then reattach new filter to old pump.
sir, i use petron diesel sa lc60 namin. siguro i'll better change the fuel filter every 6 months (or 10,000kms) to be safe. luma narin kasi yung 2B engine namin kaya mas maganda na yung malinis yung fuel palagi.Originally Posted by jim
thanks.
kaya ba DIY ito? Gusto ko sana magpalit ng fuel filter eh. Actually 2mos ago ko pa nabili yung filter ko hindi ko pa lang napapakabit dahil sayang naman kung magpapapunta ako ng mekaniko at ito lang ang gagawin. Wala bang mga adjustments na kelangan gawin pag nagkabit nito? (Tulad ng bleeding na ginagawa sa preno) By the way yung aking sasakyan ay 1994 na L200 4x2
palitan mo lang filter, bleed a little and you're done. mahirap lang naman magpalit pag tulad sa paj na masikip. kinalas ko pa buong assembly![]()
Sir OTEP, Yung plastic thingie under it - yun ba yung fuel filter sensor na may electrical wire na naka attach? Ito yata ang nakakabit sa indicator lamp sa dashboard - lights up when you have to change your fuel filter? Tama po ba ito?Originally Posted by OTEP
pwede rin or it lights up when too much water is accumulated or too much dirt ;)Originally Posted by jaeger
