Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    Feb 2006
    Mga bossing tanong kolang kung alin mas ok na VIC filter for my car. Dti kc ang tanda ko C-806 kinakabit sakin pero nun last oil change ko eh C-809. Alin ba mas mganda sa dalawa?
    Ride:00 Civic 1.6
    Thanks
    Nov 2003
    basta fit sya ok lang. i like using the largest one i can make to fit into the space so on most hondas i use 307.
    Jul 2006
    Quote Originally Posted by DRIV3R View Post
    Ride:00 Civic 1.6
    Thanks
    pre, punta ka ACE hardware sa SM. may complete list sila ng VIC oil filters for every local car applications basta alam mo lang ung engine code ng auto mo..
    Hi All!
    I read somewhere that VIC filters had very poor filtration.
    Any truth to this?
    Thanks.
    :regards:
    Quote Originally Posted by HardCharger View Post
    Hi All!
    Any truth to this?
    Thanks.
    :regards:
    Hindi siguro totoo yan. I'm using VIC and I only change oil every 10,000 kms wala naman akong nagiging problema. 307 or 806 ang gamit kong filter.
    Aug 2004
    we're using VIC filters sa landcruiser FJ60 and bighorn namin for many years. every 5000kms yung oil change and so far, wala naman naging problema.
    Feb 2006
    Quote Originally Posted by speedyfix View Post
    I dont know if I understand it correctly but I remember I read an article about using too large oil filters for your car can loose compression or pressure ba yata.Not too sure.Any one read also about this?BTW.Many thanks to all ur replies.
    Quote Originally Posted by 2Dmax View Post
    +1 dito. This is how I checked the correct ViC oil filter for the Vitara. The former owner forced-fit a Lancer oil filter kasi.
    It is also indicated on the ViC filter box what OEM part numbers it is supposed to substitute. So if you know your filter's part number, just look for it on the box.
    Sa isang Shell dito sa amin, a Nissan Patrol with a 4.2 diesel engine was fitted with the teensy-weensy oil filters intended for a Kia Pride! Wala yata yung tamang filter and nagkataon nag-match ang thread nung pang Kia. Baka hindi pa nakakalayo yun, barado na filter. hehe. Ang laki ng oil capacity ng Patrol.
    Jul 2006
    hindi basta nag-fit ung thread nila matach na. kung ano ung design intention and its application, un ang dapat gamitin..
    Nov 2003
    nah you won't loose oil pressure with a big filter as long as you compensate for the extra capacity by adding a little more oil. on my other car i have a pretty big aftermarket oil cooler and oil filter relocator kit on it which adds about 1 liter of oil capacity and i have no oil pressure drop.
    Sep 2004
    Ride:00 Civic 1.6
    Thanks
    Pareho lang diameter and mating area dimension ng C-806 and C-809, haba lang ang pinagkaiba, 75mm and 806, 80 mm ang 809.
    Pareho rin mating dimension ng C-307 sa dalawa, mas malaki lang diameter at 80mm din haba.
    mas malaki filter area mas maganda.
    Quote Originally Posted by wrcastro_ph View Post
    just make sure you get the real thing because there are a lot of fake vic filters just like 555 parts. one of the distributors is primal along banawe .
    Jul 2006
    Quote Originally Posted by Si 06 View Post
    may nabasa ko na poster sa isang store sa banaue on how to determine genuine from fake filters:
    1. electronically printed japanese prod'n code
    2. printed "Eiken Industries" on the side of the filters
    I don't know if nagaya na yan ng mga mandaraya sa mga fake filters nila..
    Anybody know pa how to effectively determine genuine from fake ones?
    Nov 2003
    best way would be to get from people who get directly from VIC dealers.
    we sell orig vic filters and 555...although mayt mga fake din talaga niyan.
    Jul 2006
    Quote Originally Posted by GlennSter View Post
    any tips on how to determine genuine from fake ones?
    up lang po.. yan din po gusto ko malaman eh.. how to differentiate orig from fake na vic products.. thanks
    Hi All!
    Any truth to this?
    Thanks.
    :regards:
    Check this site with a test of oil filters. Not saying they are bad because it could already be improved or the particular filter model was bad.
    http://www.mr2.com/TEXT/oil_filter_test.html
    we used to have posters that show the differences of the orig from the fakes...im not sure if we still have it, though.
    sorry guys for reviving a 5 yr. old thread. My car has a b16 engine, and i just saw a Vic c-805 filter at Ace hardware the other day, my question is will this fit on my engine. It is waay bigger than the 806 and a little bit taller than the 307. I would like to use larger than OEM size filters because im now using synthetic oils with 10thousand km. drain intervals, im too lazy to change my filter every 5k so im just thinking switching to a larger filter to compensate.
Vic Oil Filter
