Results 1 to 5 of 5
February 20th, 2012 01:28 PM #1
Hello mga paps!
Front crank oil seal jumps out of its seat (4x in my truck). what causes this?
1. no endplay on the crankshaft
2. no visible "canal" marks on the crankshaft
this last remedy, i put RTV silicone on the outer lip for additional grip. still under observation.
is overspeeding a big player here? medyo mabigat konti paa ko netong mga 2 beses na natanggal e. sudden WOT kasi. hehe
engine btw is 1986 model 4d56 turbo diesel fitted with a gear type oil pump
February 20th, 2012 06:32 PM #2
some possible reason on this
1.improperly seated oil seal
2.wrong oil seal( highly unlikely but still possible)
3. too high oil pressure(verify with a oil pressure gauge)
4. worn out oil seal seat
February 20th, 2012 06:48 PM #3
I normally use a fat bead of Black RTV silicon adhesive not the regular silicon gasket maker stuff, it tends to prevent the front seal from ever leaking.
You normally can't go wrong with this stuff if you have a new seal and a prepared surface.
BANNED BANNED BANNED
- Jun 2011
- 125
February 20th, 2012 08:55 PM #4
February 21st, 2012 04:15 AM #5
This is on a 4D56 there is no O2 sensor or any other sensors for that matter that this would effect. And it's is sensor safe by the way, but that's a moot point on this vehicle.
Been using it for 20 years for gasket maker on all vehicles.
https://www.autoindustriya.com/auto-industry-news/nissan-confirms-van-partnership-with-mitsubishi-fo...
Mitsubishi Philippines
