Results 11 to 19 of 19
Tsikot Member Rank 4
- Jan 2003
- 2,979
February 26th, 2010 05:26 PM #11
February 27th, 2010 02:49 AM #12
- Sep 2006
- 1,335
February 27th, 2010 08:48 AM #13hi all
the gas boy filled up Gas instead of Diesel to my friends Van (Kia), My friend asked why the gas boy filled up gas instead of Diesel. the gas boy replied "Sir, okay lang un sir tatakbo naman yan" believing what the gas boy said, my friend after filling up drove away, after 2-3 km of travel the Van started to Jerk and stalled. So my friend went back to gas station (Caltex) to complain
Question:
1. What will happen to the engine / fuel line / ? (overhaul, fush..etc)?? Effect will depend on how much gasoline was loaded. I don't think an overhaul will be necessary. Just drain the fuel system including the filter's contents, and load with fresh diesel. Car should be ok.
2.will caltex shoulder all the expenses? This will depend on how well your friend negotiates. But at the very least, the gas station should pay for a full tank of diesel, plus cost of labor for draining and refuelling.
- Jan 2007
- 187
February 27th, 2010 09:14 AM #14happened to me once... the station manager himself drained the tank. hindi naman na drain lahat pero siguro may kalahating cup of gas na natira. compressed air na lang para magig vapor ang gas. umandar naman ng maayos after. hindi nga lang namin pina andar nag malayo. just from the pump to the lift.
- Aug 2003
- 9,720
February 27th, 2010 09:41 AM #15Usually pag nagpapagas ako, i tell the guy the amount and type of fuel to fill(XCS, unleaded, etc.) Di ba naisabi ng friend mo dun sa magaling na gas boy?
Maaaring me kasalanan din ung friend mo for not being alert enough to check what fuel was being loaded...but the fact is that you brought this up with the gas boy, who fed you wrong information, thus making a bad situation even worse.
ireport nyo yan sa owner ng gas station, or the franchiser...supervisor pala siya e wala naman palang alam, nagmamarunong pa. Di pala maganda training nila sa tauhan.
At the very least they should drain your tank and load the correct fuel.
- Dec 2008
- 421
March 2nd, 2010 08:19 PM #16Good news is that you filled gas to a diesel instead of the other way around.
You should still have your fuel system drained and filled up with diesel.
I saw one episode of the amazing race when one contestant did the same thing. lucky for them that the guy in the gas station was able to drain all the fuel in the tank and replenish it with diesel in less than 2 hours.
March 2nd, 2010 10:21 PM #17
- May 2009
- 119
March 3rd, 2010 03:45 PM #18same thing happened to me with my crosswind it was a Petron Station in Sto Tomas Batangas...the gasoline girls put XCS on my 4JA1..buti na lang at before I fill up pinatay ko yung engine then napansin ko agad na gasoline yung fill-up niya kaya napastop ko agad pero around 100pesos na yung naload. The next thing we did is drain the tank....ayaw pa nila ibleed yung fuel lines but I insisted and found out na meron na din gasoline dun before the fuel filter...but after bleeding and top-up with diesel one click na ulit..after that incident switch to caltex na ako...dapat naman iorient ng mga owners ang service personnel nila about engines..yung crosswind ko nga eh may nakasulat ng "diesel" sa labas at loob ng fuel cover pero gas pa din ang nilagay...dapat iorient nilang mabuti kasi sila din ang masisira sa customer...
- Nov 2009
- 21
March 9th, 2010 01:31 PM #19happened to me once, diesel naman nailagay sa gas engine ko, di talaga inoorient mga gasoline boys kaya dapat tinitingnan i have a gasoline sticker too on my fuel tank cover. good thing bago ko inistart i saw the the gasoline boy returning the pump nozzles sa diesel kaya natanong ko, talked to the supervisor and they drained and measured the contents of the tank tapos filled it up again.
Xiaomi E-Car
