Results 1 to 3 of 3
- Jul 2013
- 48
November 16th, 2013 11:01 PM #1sir/mam need advice on what do you think? what are the pros and cons of F1-z???
meron na po ba nakapag try nito two types po daw ito single and fan double fan
meron po ba effect ito sa air flow... or designed lang po
any advice po thanks
http://tsikot.com/forums/attachment....1&d=1384610337
November 17th, 2013 07:59 PM #2
Pros? Mura.
Cons?
1. Doesn't work
2. Creates turbulence in the intake, may interfere with MAF function and cause check-engine light and/or engine failure.
3. If it's plastic, may melt and cause an engine fire.
4. Doesn't work
5. Doesn't work
6. Doesn't work
November 18th, 2013 09:41 AM #3
Ages ago, Car and Driver did a controlled test on a closed track to determine the benefits of such products. The outcome? They wasted time and money... no changes whatsoever under in performance or fuel economy.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
