Results 1 to 3 of 3
- Aug 2010
- 17
February 20th, 2012 09:19 AM #1mga experts... my ride is a nissan sunny samapalok engine which i believe has a stock carb, question ko lang po yung A/F mixture screw po ba ay may maliit na O-ring o talagang wala? kasi i tried to completly close it(close wise) pero hindi namatay ang engine eh as in hindi namatay i remembered my 12R engine pag tinodo ko sara ng A/F mixture screw namamatay yung sa akin na nissan saradong sarado na normal idle pa rin.... help naman ko.... and another thing totoo ba ang stock jetting ng carb ng nissan sampalok ay 170 Primary at 60 ang secondary or nagkabaliktad nung unang gumawa? thanks in advance po sa inyo... nakita ko yung A/F mixture screw ko walang O-ring.... is this correct?
February 20th, 2012 06:27 PM #2
afaik dapat mamatay ang engine pag totally close ang a/f screw correct me if im wrong
- Aug 2010
- 17
February 21st, 2012 09:28 AM #3i have done some reasearch ewan ko kung tama ako... here it goes...
pinaoverhaul ko yung carb ko sabi ng gumawa ok na yan titipid na yan wag ko daw muna ikabit yung air filter ko at medyo luma na daw then after several kilometers kabit ko na daw ulit pero mas maganda daw stockings ikabit ko effective daw yun... truthfully speaking hindi ako convince kasi halos ganun pa rin ang consumption and i'm running rich in fuel he said pinalitan na daw nila ng jets at nalaman ko hindi nila pinalitan kasi sa gigil at inis ko na sa auto binaklas ko yung carb i found out hindi pinalitan ng jetting kasi yung jett na nakakabit at yung dati pa rin hindi ko sinabing binaklas ko yun bago ko dinala sa kanya... akala nya siguro hindi ko malalaman ayun the 680 pesos na cost (kasama na daw pyesa dun na papalitan) e wala naman pala pinalitan at yung secondary jet ay may pasak ng parang adhesive na AFAIK eh matagal nang nakapasak dahil iba na kulay(siguro akala nung unang may ari ng sasakyan titipid pag pinasakan yung seconady jet) ayun sa inis ko yung 90 na stock jet pinalitan ko ng 80 at yung stock secondary jet na 145 ay pinalitan ko ng 95 timpla timpla ulit ng A/F mixture, niluwqagan ko ng todo nung natanggal yung screw namatay makina (hindi katulad nung una na 90 yung primary eh kahit tanggal yung screw hindi namamatay yung makina) ginamit ko yung sasakyan for about 6.5 kilometer then check the plugs ayun choco brown na ulit at hindi na itim na uling. kanina umaga sinubukan ko yung stockings ang kinabit (kumupit pa ako ng stockings sa closet ni misis) kinabit ko sa nozzle ng air filter casing bumili ako ng gasoline nilagay ko sa 1.5 bottle ng coke nirekta ko yung hose mura fuel filter hanggan sa bottle pati yung return nirekta ko sa bottle at yung bottle ay nasa paanan ng co driver's seat (para kitang kita ko
) sabi ko kay wifey buksan muna window kasi baka mahilo tayo hehehe umalis na kami going to work (6.5Km from house to work) ayun naubos lang ng sasakyan 6.5Km is 750ml(nilagyan ko kasi ng pentel pen yung 250ml level, 500ml, 750ml, 1000ml, 1250ml at yung 1500ml using graduated cylinder na hiniram ko sa science lab ng anak ko
) so by computation (1000ml / 4 = 250ml x 3 =750ml then 6.5km / 3 = 2.16km x 4 = 8.66km) so therefore na prove ko na i'm averaging 8.66km/L of gasoline
city driving with uphill and downhill of about 1km from house to main road with light trafic kasi past 7:00AM na kaya madami na jeep na nagsasakay at nagbababa ng students.
mga ginawa ko para makuha ko yung tamang tipid:
1 tinanggal ko yung mga tools:
(crocodile jack, i set steveman socket with metal case, 1 set steveman deep socket with plastic case, 1 set alen
key, 1 set star key, 1 set 24pcs combination wrench, 1 set 12pcs open wrench, i tool box with adjustable wrench,
vise grip set of screw drivers, torque wrench)
2 palit jetting from 90 to 80 primary at from 145 to 95 secondary
3 tinanggal ko yung lumang air cleaner element kinabitan ng stockings courtesy of wifey
4 pitik pitik lang sa gas pedal
i hope some of our friends here wag mangyari yung nangyari sakin... bago kayo magpagawa pagaralan nyo na lang mabuti sayang ang pera 680 pesos plus gasoline(syempre tetestingin nyo yun so waste of fuel lang) tama rin ang sinabi ng kapit bahay ko "sa kagustuhan mo makuha ang tamang consumo ng sasakyan mo"
I hope this will help... may mga gagawin pa ako research of tweaking my ride baka mapatipid ko pa ito dahil baka pwede pa ako mag adjust ng A/F mixture kung kaya pa...
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
