Results 1 to 10 of 11
January 6th, 2009 09:23 AM #1
Is there a potential link to use of Auto-LPG and fuel pump failure?
In some of our vehicles, an electrical relay was installed to activate/deactivate the fuel pump when LPG system was off or on. This was meant as a preventive measure because it has been observed in some vehicles that even with the LPG system running, gasoline (under pressure) is leaking through the closed fuel injectors. I am curious adding the relay can cause a condition for the fuel pump to fail prematurely?
I am also concerned with a potential problem with Auto-LPG use with cars with returnless fuel systems. Since there is no traditional fuel return line, the fuel is not moving and yet the pump is keeping the pressure in the fuel line. Will this static pump pressure condition have a potential to lead to premature pump failure?
THE AUTO SPECIALIST
- Mar 2006
- 607
January 6th, 2009 10:41 PM #2with properly installed lpg conversion kit, this shouldn't be an issue .
January 6th, 2009 11:17 PM #3
THE AUTO SPECIALIST
- Mar 2006
- 607
January 7th, 2009 10:53 AM #4the pump for the returnless fuel systems are designed to stand let's say constant 55-64psi ( GM 4.3L VORTEC ENGINES)
so i don't think it's a concern at all
unless there really was a problem on the injectors in the first place
January 7th, 2009 11:37 PM #5
Logically, it might pose a problem. Since the fuel pump wasn't designed to produce and contain very high pressure (unless it has a pressure switch like the ones installed in household and industrial water pumps).
the best thing to do is cut off the power to the pump.
January 7th, 2009 11:43 PM #6
THE AUTO SPECIALIST
- Mar 2006
- 607
January 8th, 2009 11:04 AM #7if you want to know more about returnless fuel systems just let me know .
and if you happen to personally experience openning a gas tank with returnless, you will know more that the pump itself has a regulator built-in to it .there is even has a pressure sensor built - in too.
i have all kinds of technical info regarding of fixing cars , and i have the info available to your questions.
what i just want to say is the simpliest way to understand , but if you want to know the ins-and outs, let me know
i do a fleet maintainance to the taxis around ( CANADA) and these have a dual fuel systems ( PROPANE/GASOLINE) and how we do it is a little bit different . we are licenced to do those systems . we don't have to cut the fuel pumps off. it's running all the time the engine runs .
so i'm going back to my first post , it's not a concern at all.
but if you still want to cancel the fuel pump while on lpg, it's just simple ,
you can have the original fuel pump relay cut with on/ off switch.you don't need another relay.
there are cases that the ecm can sense the faulty circuit so you may have to live with it
- Aug 2008
- 7
January 23rd, 2009 12:18 PM #8Help!
Ive been using LPG for 5 or so months straight, didnt use the gasoline
Now when I tried gasoline it will not start at all. (the Gaso tank has been empty for a few months before i filled it again)
The mechanic said, goodbye fuel pump and nozzles; but new ones
Is there any ideas from you folks?
thank you
January 23rd, 2009 12:51 PM #9
- Aug 2008
- 7
January 25th, 2009 02:44 PM #101. Are you saying the Fuel pump gets broken that way and is now actually broken?
2. adding a relay?
3. That will cost me something like P5,000? in all?
if I had known.............
Still accessing via Tapatalk. Still laggy. I need to open a notification to follow “Tsikot”...
tapatalk smart phone application.
