Using your car with a dry gasoline tank and running fuelpump motor will lead to premature pump failure for sure. Adding a relay (greenfuel can do it if you had your system installed by them) will prevent this from happening.
Actually that point already has been mentioned over and over again in the main auto-lpg thread. Keep some gasoline in your tank to prevent premature fuel pump failure.if I had known.............
