Quote Originally Posted by rpxhost View Post
Help!
Ive been using LPG for 5 or so months straight, didnt use the gasoline
Now when I tried gasoline it will not start at all. (the Gaso tank has been empty for a few months before i filled it again)
The mechanic said, goodbye fuel pump and nozzles; but new ones
Is there any ideas from you folks?
thank you
You can replace the busted fuel pump motor with a replacement motor.
And then add a relay to disable the motor whenever you are using LPG.
