Results 1 to 10 of 12
- Jan 2009
- 8
January 23rd, 2009 11:30 PM #1totoo ba ung kapag bigla kang narelease ng silinyador ay nahigop ang exhaust?
di namn cguro totoo yun di ba?
January 23rd, 2009 11:33 PM #2
false. The exhaust gas velocity simply slows down. It never reverses in flow.
January 23rd, 2009 11:35 PM #3
Tsikot Member Rank 4
- Jun 2006
- 2,605
January 23rd, 2009 11:38 PM #4
January 24th, 2009 07:00 AM #5
hindi po totoo may nahihigop sa exhaust.. kya may water kasi normal lang po yan dahil humid po sa loob ng exhaust natin sir
- Aug 2004
- 164
January 24th, 2009 08:22 AM #6
No... I agree with Ghost et al
If you're worried about the water droplets coming out of the tailpipe, it's normal when the pipe is still cold. Exhaust gas consists of water vapor, carbon dioxide, carbon monoxide, unburnt fuel, carbon particles, etc. What you see is the water vapor condensing into liquid water .....
Safe driving!
January 24th, 2009 09:29 AM #7
kaya useless ang hard revving on flood forging... be wary more of your intake than our exhaust...
January 24th, 2009 12:02 PM #8
- Jan 2008
- 4,726
January 24th, 2009 12:49 PM #9not a chance.. exhaust will always blow out what ever comes in.. but in flood, when the tail pipe is submerged, you need to keep the engine above idle to prevent it from stalling.. when the tail pipe is submerged and you let the engine idle in flood, the water volume will be enough to block the tail pipe stalling the engine.. once the water goes inside the tail pipe, you will have a hard time cranking the engine again since your exhaust is blocked
January 25th, 2009 12:40 AM #10a car will be the most expensive vacuum cleaner anyone ever bought! hehehe
most of the time, it's the tailpipe doing the the first dip since it is lower than the intake. probably part of the design to save the engine.?.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
