Results 1 to 10 of 20
- Jul 2012
- 113
December 15th, 2015 08:21 AM #1Hi mga Gurus,
Question lang po, kaninang umaga kasi na-experience ko yung vibration while idle and stop and go (low speed with braking).
Then even nakapark may vibration siya pero lesser compare kapag nasa D ako. Ano kaya ang cause neto?
Previous na ginawa sakin eh, change rear wheel bearing and brake shoe.
Thanks sa sasagot.
- Jul 2012
- 113
December 15th, 2015 09:20 AM #3
December 15th, 2015 09:30 AM #4
mas makakatulung ang mga gurus sir kung sabihin nyu details ng car like: engine, ilan taon, brand, any aftermarket mods?
December 15th, 2015 09:51 AM #5
IMO causes of vibrations-
1. Engine Support
2. Transmission Support
3. Engine Timing/ Fuel Pump Timming
4. Clogged or dirty Fuel Filters.
5. Clogged fuel tank breather
6. Transmission/ jack mo yung tranny mo... kung mawala pwedeng tranny support or mismong transmission mo may problema na...
7. crossjoint sa differential
- Jul 2012
- 113
December 15th, 2015 10:03 AM #6
December 15th, 2015 11:28 AM #7
When was the last time napalitan ang engine support nyan?
Nung pinatignan mo ba naka lifter yung car para ma inspect properly yunf engine support? Konting crack lang kasi nyan or isa lang dyan malambot na mag vibrate talaga yan.
For all others nalista na ni Glenn
Sent via Tapatalk
December 15th, 2015 11:49 AM #9
10 y.o. car
Clean throttle body
Clean idle air control valve
Clean/replace PCV valve
Perform ignition tune up
- Dec 2015
- 6
December 19th, 2015 05:53 PM #10YES! Great piece,Chartered Accountant Firms in Karachi
keep up the terrific work This is the type of information that should gain recognition for it’s craft More writers should learn from you.
This is right on the money. great site i must say.Chartered Accountant Firms in Islamabad
.very enjoyable stuff is placed here in a very appropriate way..thanks for publish this site…thanks for publish it..its a good attempt..
With this sort of gadget the thing to keep in mind is "you get what you pay for". I've been in...
Rear view mirror dashcam, help me choose...
