Results 1 to 20 of 20
    Jul 2012
    Hi mga Gurus,
    Question lang po, kaninang umaga kasi na-experience ko yung vibration while idle and stop and go (low speed with braking).
    Then even nakapark may vibration siya pero lesser compare kapag nasa D ako. Ano kaya ang cause neto?
    Previous na ginawa sakin eh, change rear wheel bearing and brake shoe.
    Thanks sa sasagot.
    check mo iyong mga engine support mo baka kelangan palitan na
    Jul 2012
    boss, last week napa check ko na din, kasi ngpa check ako ng suspension ko, kasama yun sa tinignan, okay naman daw..
    my iba kang alam na culprit?
    Oct 2015
    mas makakatulung ang mga gurus sir kung sabihin nyu details ng car like: engine, ilan taon, brand, any aftermarket mods?
    Jun 2011
    IMO causes of vibrations-
    1. Engine Support
    2. Transmission Support
    3. Engine Timing/ Fuel Pump Timming
    4. Clogged or dirty Fuel Filters.
    5. Clogged fuel tank breather
    6. Transmission/ jack mo yung tranny mo... kung mawala pwedeng tranny support or mismong transmission mo may problema na...
    7. crossjoint sa differential
    Jul 2012
    Quote Originally Posted by PJ Sinohin View Post
    Aww okay boss, eto details.
    Toyata Altis 2002, no mods, stock po lahat, recent na ginawa this sunday lang, change rear wheel bearing and brake shoe.
    Sep 2012
    When was the last time napalitan ang engine support nyan?
    Nung pinatignan mo ba naka lifter yung car para ma inspect properly yunf engine support? Konting crack lang kasi nyan or isa lang dyan malambot na mag vibrate talaga yan.
    For all others nalista na ni Glenn
    Sent via Tapatalk
    Jul 2012
    Quote Originally Posted by jodski View Post
    Sent via Tapatalk
    Boss, last week lang din. Yes tinaas po siya.
    Feb 2009
    Wrong post
    Feb 2009
    10 y.o. car
    Clean throttle body
    Clean idle air control valve
    Clean/replace PCV valve
    Perform ignition tune up
    Dec 2015
    YES! Great piece,Chartered Accountant Firms in Karachi
    keep up the terrific work This is the type of information that should gain recognition for it’s craft More writers should learn from you.
    This is right on the money. great site i must say.Chartered Accountant Firms in Islamabad
    .very enjoyable stuff is placed here in a very appropriate way..thanks for publish this site…thanks for publish it..its a good attempt..
    Jul 2012
    Yung pang 3 po na fuel injector niya mukhang my sira na that causes the engine to vibrate, na test ko siya kasi kapag tinatanggal yung cable niya hindi ngbabago ang engine while yung iba ngbabago. So pinalitan po namin ang fuel injector but still the vibration persist, and hindi padin gumagana. I Think electrical na problem at hindi ang fuel injector. Tingin niyo?
    My naka experience na po ba neto?
    Jun 2011
    Quote Originally Posted by anakngsultan View Post
    Baka naman high tension wire ang kailangan Mong palitAn...
    Jul 2012
    Not familiar with tension wire boss, para san po ba yun?
    Jun 2011
    YuNg tinangal Nyo Sir na cable-- na nakakabit sa spark plugs..
    Jun 2011
    Does your system have any or combination of PO300, PO301, PO302, PO300 and/or PO304?
    Feb 2009
    Is the check engine lit with them engine running?
    normal lang ba na mag-vibrate talaga yung 3-cylinder engines?
    Feb 2009
    Quote Originally Posted by eon red View Post
    Normal to some extent. If the idle speed is lower than specs it gets worse.
    Feb 2009
    Smart phone decides to send codes[emoji89]
Help : Car Vibration
