Quote Originally Posted by haragan View Post
Hi mga sirs,
I recently had my Lancer 82 model repaired and the mechanic said that i need to change two oil seals and the timing belt.
so i bought the oil seals and timing belt. I was hesitant to change the timing belt since i had a bad experience previoulsy with replacing timing belts.
So after the changes i did a test drive and everything went fine. after a week of driving my car stalled and it wont start. To make the long story short, na wrecker ako and when the mechanic checked the engine is stock up..
May guhit sa first valve nung camshaft so sabi nila need daw i pa machine shop.
My real question is, pag incorrect ba ang installation ng timing belt mag cacause ba un ng engine stock up, or di mag pump ng maayos ung oil.
Sa case ko kasi sabi ng mekaniko madumi daw ung langis at di sya nag pump ng maayos kaya nag stock up ung makina.
Help me naman po para ma defend ko ung pag request ng back job sa unang mekaniko na gumawa. Ang laki kasi ng ginastos ko sa unang gawa tapos mas lumaki pa because of this engine stock up.
Thanks sa laht ng replies
Just to make a correction. The word should be STUCK - past tense of STICK - not STOCK..
Peace.
