Results 1 to 4 of 4
- Aug 2003
- 9,720
April 16th, 2007 07:35 AM #1lately, bumalik ung sakit eng ride ko, i.e. parang binibilaukan ung engine when cold. it would running smoothly, then biglang magstall/surge out of nowhere. this happens when the engine is cold, although it hasn't behaved this way ever.
i made a quick inspection of the engine bay, and found this:
apparently the portion of the air filter directly above the carb jets appear burnt. ano kayang ibig sabihin nito?
i had some overheating problems a few weeks back, pero solved na siya; effect kaya ng pag overheat yung pagkasunog sa filter?
tia
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Aug 2003
- 9,720
April 16th, 2007 03:11 PM #3aside from the burnt filter, there are some burn marks around the air filter assembly.
is it possible that the a/f mix is getting burnt prematurely, kaya nasunog ung filter? e.g air flows into the throttle body, which sucks in fuel further down along the body, a/f mix gets ignited there before it gets into the cylinders.
what could've ignited it, though? stray sparks? unusually high engine temperature gawa ng pag overheat?
- Nov 2003
- 3,849
What happened to this place kaya? I remember they launched with a bang. Celebs pa and all that.
Hybrids and EV
