Results 1 to 8 of 8
- Apr 2007
- 20
September 21st, 2007 02:35 AM #1sir(s),ask ko lmang.my ride is mitsu lancer 94 glxi(A/T) * npansin ko na nmatay na pala ung makina ng walang indication or warning like panginginig.bale nasa stop and go traffic situation kmi * panay salida lmang ang takbo nmin den ng mag go go na di kmi umandar * npancin na lmang nmin na patay na pala ung makina.restart d engine * 1 click lmang,ano po kya problema noon?thanks and more power.
September 21st, 2007 08:21 AM #2
madaming pwedeng panggalingan ng problema bro.
check the following
-air filter
- spark plugs
- fuel filter
anong gas kinakarga mo? stay with 95 RON and up
btw, how's your servo?
September 21st, 2007 09:23 AM #3
If the idle is somewhat erratic, try to check your servo, it's a common problem on EFI cars as they age (had this problem on our Galant before).
September 21st, 2007 09:32 AM #4
feeling ko electrical related yung problem ng oto mo, pa check mo na din yung lines.
kung fuel-related kasi yung problem, medyo pupukgak-pugak muna bago mamatay.
September 21st, 2007 11:11 AM #5
Bro,
The same thing also happened to me before (my ride is an EFI vehicle also). It turned out my alternator was already defective. I had to have it replaced. Most probable reason your car shuts off is electrical. Have it checked by a competent shop, have him do an isolation test.
- Apr 2007
- 20
September 22nd, 2007 02:18 AM #6mga bro,thanks for your quick replies.btw,my gas is xcs(petron),air/fuel filter still ok,ung spark plugs 2yrs old na(platinum),my idle is ok d nman erratic den ung A/T oil 1month old bale bagong palit * k nman ang hatak.cguro pa check/service ko muna ung servo unit * pa chek ko din ung electrical system ko specially the alternator.btw,i'm using maintenance free battery bale 1yr and 6 monts old na un.ung ang ecu kya mga bro?thanks and more power to all of us.
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 23rd, 2007 12:11 PM #7Correct me if I'm wrong. AFAIK, if the alternator is defective, the battery take up the load, until its drained. Since you were able to restart the car, then that means your battery was still charged.
Still, it won't hurt to have your electrical system checked.
Tsikot Member Rank 5
- Nov 2003
- 3,849
