Results 1 to 16 of 16
    May 2004
    I have a 1996 4g63 mitsubishi chariot. Pag nag accelerate ako starting from 80kph upwards nanginginig and makina. Ano kaya ang problema? Tnx.
    Sep 2006
    engine mount maybe.are you sure its the engine not the steering that's shaking?
    sigurado ka engine? check the ff:
    - engine and transmission mounts
    - di kaya engine knock narinig mo? check timing belt baka tumalon sa pulley ng 1 tooth or more. check also ignition timing.
    or sa steering nanginginig?
    May 2004
    Not the steering, actually the whole car is shaking lalo na pag diniin un gas pedal from 80 to 120 kph. Pina check ko na tires, rims ok naman. Engine mount and drive shaft pinacheck ko ok naman. Pag ignition timing ang problema di ba dapat pumapalya? Pag timing belt, di ba tumataas dapat engine temp pag di maganda pagkakabit? Thanks for the replies pa check ko uli next week.
    did you change timing belt? if yes diba may engine balancer ang mga mitsu engines baka hindi tama sa timing ng balancer.
    wheel balance?
    May 2004
    Quote Originally Posted by ARB View Post
    Nagpapalit ako ng timing belt mga one year mahigit na. Na mention nga ng mekaniko na nag check na baka raw engine balancer nga dahil ito na lang di nacheck. Tnx sa reply.
engine shaking
