Results 1 to 16 of 16
    May 2004
    I have a 1996 4g63 mitsubishi chariot. Pag nag accelerate ako starting from 80kph upwards nanginginig and makina. Ano kaya ang problema? Tnx.
    Sep 2006
    engine mount maybe.are you sure its the engine not the steering that's shaking?
    sigurado ka engine? check the ff:
    - engine and transmission mounts
    - di kaya engine knock narinig mo? check timing belt baka tumalon sa pulley ng 1 tooth or more. check also ignition timing.
    or sa steering nanginginig?
    May 2004
    Not the steering, actually the whole car is shaking lalo na pag diniin un gas pedal from 80 to 120 kph. Pina check ko na tires, rims ok naman. Engine mount and drive shaft pinacheck ko ok naman. Pag ignition timing ang problema di ba dapat pumapalya? Pag timing belt, di ba tumataas dapat engine temp pag di maganda pagkakabit? Thanks for the replies pa check ko uli next week.
    did you change timing belt? if yes diba may engine balancer ang mga mitsu engines baka hindi tama sa timing ng balancer.
    wheel balance?
    May 2004
    Quote Originally Posted by ARB View Post
    Nagpapalit ako ng timing belt mga one year mahigit na. Na mention nga ng mekaniko na nag check na baka raw engine balancer nga dahil ito na lang di nacheck. Tnx sa reply.
    Nov 2006
    ang problema mo ay yung tinatawag na cyclic vibration and it comes and goes between 75 to 100kph.a more likely cause is a bad inner tripod CV joint.the vibration occurs dahil sa ang isa sa tatlong roller tracks has become dimpled or rough,kaya every time the tripod roller on the bad tracks hits the rough spots,mag create sya ng little jerk in the driveline,which the driver feels a cyclic vibration,,kaya begin mo ng ipacheck yung CV joint.
    May 2004
    Quote Originally Posted by dennis powell View Post
    OK, salamat, pa check ko rin ito.
    not likely the balance shafts, kasi magvivibrate din engine mo at idle or habang stationary ang car kung wala sa timing ang balance shafts. more like nga ito sa cv joints (as per dennis). na involve ba sa accident ang car prior sa vibration problem mo. or it could be a badly tuned engine
    Pasali na rin sa thread...
    Guys patulong naman, I used to have a problem with my shifter, ang hirap pumasok sa 2nd gear, and may krug krug sound pag aandar na yung oto. Until one incident, hirap ko na makapa yung gears, talagang hindi ko na maipasok sa 2nd gear, I thought it was a bushing problem. So dinala ko sa mechanic, may ginalaw lang sa ilalim ng kotse (near firewall and tranny) then voila, ang lambot na ng shifter ko and ang dali nang ipasok ng gears, nawala na rin yung krug krug sound pag mag aaccelerate...
    Nung pauwi na ako galing mechanic, at highspeed (60kph, not that high I know, hehe) nag start na mag wiggle nung kotse. Inobserve ko for several days, hindi nawala, then binalik ko sa mechanic, engine support daw, so he had my old engine support replaced...
    Strong vibration at idle, especially when AC is on yung naging result. Sabi ganun daw talaga since matigas pa mashado yung rubber. I can deal with that, pero ang problem, hindi naman nasolusyonan yung wiggle at highspeed problem ko. In other words, nagkaron ng strong vibrations tapos nagwiwiggle pa rin at highspeed yung kotse ko.
    I am certain hindi related sa gulong/alignment/balancing yung problem since kapag mabilis na yung takbo at naka 5th gear na ako at sobra na yung nginig, when I shift back to neutral pero high speed pa rin, nawawala ang wiggle nung kotse at very smooth yung takbo.
    Again, ang sabi nung mechanic, kulang daw ang engine support ko, 3 lang dapat daw 4. Nung tinanong ko naman dun sa nag mount ng engine ko, 3 lang naman daw talaga mga kinakabit nilang support, wala naman nagiging problem.
    Saan kaya talaga ang problema nung nginig ng kotse ko? I still think engine support eh. Pero how come na right after may galawin lang yung mechanic dun sa ilalim ng kotse ko para ayusin yung shifter ko, lumabas yung nginig? Sandali lang ginalaw dun sa may ilalim, ang sabi pa, meron lang daw nagkakaskasang mga bakal, so parang inadjust lang. BTW, kia pride yung ride ko, pero mazda engine and tranny na yung naka install.
    Please help. Thanks.
    Aug 2004
    Better post this in a separate thread for more visibility.
    Better yet, head on over to protegetech.org and ask KiaDohc for advice... siya yung resident expert sa Kia-Mazda swaps.
    Nigo,
    D Powell and t2ern have good points. But it is very important that you know whether its an engine or a drivetrain vibration. Try to drive it on a good asphalt road, aircon and radio off and try to listen whether its left, right or center.
    Nov 2006
    Exacto, ganito ang nangyari sa car ko before.
    Nanginginig buong car pag nasa 70kmph pataas.
    nagpalit ako ng rear tires, akalain mong nawala. Ngayon kahit ibirit mo ng 140kph walang vibrations.
    Apr 2006
    Quote Originally Posted by chiekot View Post
    ganito rin naeexperience sa '96 corolla namin.
    upod na mga tires. coud it be the only reason kaya nagkakaganon un???
    or wheel alignment din?
engine shaking
