Results 1 to 10 of 10
August 9th, 2015 10:05 AM #1
Guys, help.
Yung engine kakaiba yung vibration nya when running at high speed or around 4th and 5th gear.
its kinda violent na I can feel it shaking my ride compared to normal engine vibration.\
then ang pag nag shake na sya, bibitawan ko lang yung gas and go to neutral, magiging normal na ulit
wala naman weird noise. ok din ang engine rhythm pag low speeds; 1st 2nd 3rd gear.
my engine is 4d56, mitsu adventure 1st generation
any idea anong problem? THANKS!
- Jul 2015
- 9,583
- 53,003
August 9th, 2015 10:48 AM #3a friend once had this problem... i'll ask him what he found.
but it definitely wasn't fuel.. it was engine..
August 9th, 2015 11:19 AM #4
Almost same problem, pero automatic yung akin. When in D and stop, nagba-vibrate yung engine, although pag umandar na eh nawawala ang vibration, nawawala rin when shifted to N or P. Had it checked out, inayos yata yung engine mount, then cleaned the servo, cleaned and adjusted the spark plugs (inusog yung bato). Bawat ginawa nya eh nag test. Nakikita ko naman na unti unti nawawala vibration sa mga test nya.
August 9th, 2015 12:04 PM #5
Please do Dr. D. I'll have my engine check this week. sana hindi serious problem. and btw diesel po.
- Nov 2009
- 3,490
August 9th, 2015 12:08 PM #6Id check engine and tranny mounts, they wear over time. May visible leaks ba o crack/stress marks sa rubber?
August 9th, 2015 01:51 PM #7
Thank you for the input 12vdc. There are no leaks. I haven't checked it thoroughly.
August 18th, 2015 05:33 PM #10
Sorry for late reply. Thank you for all the inputs. It was indeed tranny mounts. atleast pumunta ako sa autoshop knowing the issue. now its fixed, naninibago ako sa vibration feel ng auto ko.
Gamet ko cone filter kapag ba malakas Yung higop Ng hangin servo motor na tlaga sir
LANCER Itlog (93-96) Owners - Please Post Here!
