Results 1 to 10 of 10
May 7th, 2007 09:10 PM #2
sir, counter-clockwise po para po lumakas ung air and mararamdaman mo naman po kung tataas ung menor mo or ask somebody to check ur RPM kung nagbabago. yan po ang turo ng mechanic ko when i had this prob sa IDLING ko when my A/C is on.
May 7th, 2007 09:36 PM #3
I suggest you go to a trusted shop, kasi kung do it yourself medyo tricky yan. pag masyadong tumaas lakas sa gasolina nun pag masyado namang bumaba baka mamatayan ka parati ng makina. A good mechanic knows how to properly set it dependent on the requirements of your car. Anyhow when you go for a tune up kasama yan sa standard service.
May 8th, 2007 08:55 AM #4
- Dec 2006
- 40
May 8th, 2007 09:26 AM #5mga paps,
saan ba location ng idle speed adjustment sa 4afe engine ng corolla gli? balak kong subukan dahil medyo mataas timpla ng idle ko. nasa 1k. nakalagay sa hood mga 800 +- 50 lang dapat.
tia.
May 9th, 2007 09:38 AM #7
it's on side of the carb morpheus, you know where the throttle linkage is, yung end ng cable connecting d gas pedal to the carb...it's usually a slotted (flat head) screw protruding...it's turned counterclock wise till the throttle linkage stops, then 6 - 8 full turns clockwise to the desired idle speed...use a a designated dwell/tachometer and not the dashboard tachometer for a more accurate reading/ adjustment.
- Feb 2007
- 12
May 9th, 2007 10:18 AM #8Hoow about po sa Civic Vtec, paano po pagadjust ng idling? kasi pag bagong start ung makina ang taas ng idling 1.5-1.75. dati kasi padumandar na ko bababa din agad kaya this past few days ang tagal bumaba lakas tuloy sa gasolina
- Dec 2006
- 40
May 9th, 2007 11:01 AM #9
- Feb 2006
- 43
May 9th, 2007 03:07 PM #10AFAIK, for efi, the computer box automatically adjusts the idle. Bring it to your trusted mechanic if ever you encounter problems with your idle. Alam ko may nililinis sa servo.
I avoid slots with pick-ups nearby.
PH Gov't looking to bring back excise tax for...
