Yes, the lamp should be enough. Makikita mo naman kung working ang sender unit upon switching to ACC position and firing the engine. Basta larger surface area ang filter means lesser restriction, just dont go smaller than the OEM and follow the OCI then you should be fine even without BPV.
Thanks a lot, bro 12vdc! Kaya ko use this B143 non BPV oil fiter is to test if the BPV is the reason why dark agad ang oil after 1,500 kms, my old filter is B131 with 8 psid BPV pressure setting. I'm thinking, it passes unfiltered oil easily when accelerating or in high rpm. Now, I'll know if in same mileage, same color pa din, hindi ang BPV ang culprit.
Medyo confident na ako ngayon! Thanks!
Posted via Tsikot Mobile App
