Since we are at tropical climate, using larger filter should not be a problem. The oil pressure sender is located after the oil pump and will detect no pressure if there is no oil, filter badly clogged, or the pump is busted. Assuming your sender unit is in working condition, it should turn on in the meter cluster if it detects low oil pressure or oil starvation.
