Quote Originally Posted by slvrsrfr2301 View Post
checked, sabi ng mechanic namin, cylinder head o gasket daw .... pero di ako mapakali sa oil ko, kasi nasanay sasakyan ko sa 5w-30 di sa 10w-38 na naka karga sakin... anyway, papagawa ko bukas yung sasakyan ko :D thanks sa mga info mga sir!!!
The 5W30 is thinner than the 10W38.... Your "oil leak" must be coming from the new oil spilled around your filler or from the oil filter mounting when you dismantled your filter (when you had a change oil). Best thing to do first is have your engine washed (while cold) to determine better the source of leak
